Old 21st June 2009, 22:45   #1
blairlinn
Garage: M5 E34 daytona violet
EDC suspension woes
One front EDC strut shot and now one back one. Car feels like a pudding to drive. I've managed to buy a set of four through our favourite auction site - they look much better than mine but I'd like to ask advice from the experts on any pitfalls to expect in fitting them and are there any things you would suggest changing at the same time. Thanks
P.S. If it all goes pear shaped at least I'll have a set to get refurbed
blairlinn is offline
Old 21st June 2009, 23:39   #2
Baddie
Garage: M5 Daytona Violet 3.8
Hi mate
I can't advise re fitting dampers and SLS (bleeding the pentosin is beyond my experience), but I would recommend changing all suspension bushes at the same time based on my changing mine piecemeal and noting a significant incremental improvement with each change. I also have a set of unused front topmounts if you're interested.
Cheers, Anwar
If you focus on quality, you don't need to worry about quantity.
Baddie is offline
Old 21st June 2009, 23:56   #3
davidoli
Congratulations on finding 4 replacement dampers .
What tests have you carried out to ensure that it is worth the labour intensive task of fitting all 4 to your car , as it would be an awful shame to carry out the work only to discover that there is no tangible improvement .
Assuming that the dampers are good and none of your existing components such as top mounts , upper and lower control arms , rear subframe bushes , arb bushes , pitman arms etc etc are worn , then I would simply swap the dampers over and assess the results .......otherwise you may be basing your assessment on the improvement brought about by renewing other components .
When removing the sls pipes at the base of the rear shocks , use 2 17mm spanners ( IIRC ) to crack the fittings off against eachother and minimise the risk of twisting the pipes .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 22nd June 2009, 01:51   #4
Baddie
D
As usual Dave I can only agree with your ever-eloquent advice particularly on the need to identify the precise nature of the problem. Perhaps you would agree that bushes are often forgotten in the context of previous damper changes, are often worn out long before the arbitrary 100,000 miles often considered acceptable for dampers, and in the absence of a damper change have quite likely never been changed.
I was very surprised just how much tight new bushes contributed to the correct function of new dampers. The ride, braking, steering were all appreciably more controlled. I have been so pleased with the improvement at comparatively modest cost I plan to change them at 3-4year intervals.
Baddie is offline
Old 22nd June 2009, 23:21   #5
blairlinn
You asked if I had done any test on the new units - can you outline any tests I should carry out.
I appreciate the offer on the top mounts and would be interested as I don't see any point in not replacing them. Thanks
Old 23rd June 2009, 01:00   #6
davidoli
Baddie , you are 100% spot on re the importance of the various steering / suspension parts and their remarkable effect on overall handling / steering , turn in and control .
My concerns and advice was based on the fact that our fellow member , Blairlinn , had opted to buy second hand units , sight unseen , and may therefore be considered to be working to a budget .
The fact that Blairlinn now does not see any point in not replacing the top mounts , even if his current items are in perfect usable condition , would suggest that I have made an incorrect assumption .
Good luck with your damper change Blairlinn , renew as many parts as you can and , assuming that your replacement dampers are efficient , your M5 should feel much improved .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 23rd June 2009, 19:03   #7
Baddie
Cheers David, agree with your approach to 'target' problems and expenditure.
As enthusiastic owners we are torn between spending the money these thoroughbred cars would ideally require, spending money that's in proportion to their current value, and spending what's actually in our pockets!!!
Anwar
Baddie is offline
The Following User Says Thank You to Baddie For This Useful Post:
davidoli (23rd June 2009)
Old 24th June 2009, 00:29   #8
blairlinn
Anwar can you give me price details for the top mounts please.
If anyone needs a complete front bumper I've got a spare one as I screwed up in thinking I could replace my damaged front spoiler by unbolting it from the complete one - didn't know it was all the same moulding !!
Old 24th June 2009, 01:51   #9
Baddie
Originally Posted by blairlinn View Post
...thinking I could replace my damaged front spoiler by unbolting it from the complete one - didn't know it was all the same moulding !!
Happens to me all the time and have a small inventory of obscure parts
I've sent you a pm about the top mounts if you're interested.
Thanks, Anwar
Baddie is offline
Old 14th July 2009, 01:58   #10
blairlinn
Started to strip off rear dampers today - didn't know the rear seat had to come out - what a struggle that was! Bottom bolt and spigot were solid - it took an hour to get the bottom mount off. Turns out I've got a broken spring.
Can anyone advise the best dealer in the area for parts discount (Stirling, Glasgow or Edinburgh). Thanks
B8 Suspension woes... Adam ALPINABoard.com | BMW Alpina Discussion 42 19th April 2006 00:18
Suspension woes...experts opinion needed. Sweetsound2001 E39 M5 and E52 Z8 Discussion 8 19th June 2005 16:50
B8 suspension woes. Adam ALPINABoard.com | BMW Alpina Discussion 5 20th May 2005 00:02
More Suspension woes (SLS) Brian M5 E34 M5 Discussion 3 11th April 2005 14:39
A/C Woes SteveC E34 M5 Discussion 6 5th August 2000 17:17
Page generated in 0.14871 seconds with 11 queries
