Old 16th June 2009, 04:28   #1
marekd174
Garage: 92 M5T , 85 M5
E34 M5 valve shims
I remember ordering these from an on-line place in the US that has other BMW parts and now can't for the life of me remember where it is or find the receipt for the shims.
They were less than $5ea and I think it is a well known place.
Anyone?
marekd174 is offline
Old 16th June 2009, 07:41   #2
OhneKompromiss
Garage: 1991 M5, Black on Black
I'm fairy certain that Pelican Parts carries these shims. They also sell the valve depressor tool and the other bits and pieces you'd need to do a valve adjustment.
OhneKompromiss is offline
Old 16th June 2009, 12:34   #3
marekd174
I have the tool already and it's not Pelican Parts as they don't list any of the bigger shims on their website and the shims are $9.50ea.
It's another BMW parts place
Old 16th June 2009, 14:43   #4
Konfused Pete
Konfused Pete's Avatar
Garage: Black '90 e34 M5
BMAparts ?
Konfused Pete is offline
The Following User Says Thank You to Konfused Pete For This Useful Post:
marekd174 (16th June 2009)
Old 16th June 2009, 16:06   #5
marekd174
Yes that's the one thank you Sir!!
Old 17th June 2009, 01:19   #6
woods
Garage: 91 M5 - Diamantschwartz
BMA sells Volvo shims (no chamfer)... They work fine though. You can also buy the entire Volvo 100 piece shim kit for only $200... Shim sizes seem to be in line with what my motor is equipped with but YMMV.
http://www.autopartsway.com/AutoParts2/index.cfm?fetch=altPart~ID=W0133-1604802&partnumber=W0133-1604802&a_aid=176b5dca&data1=frugalmechanic
woods is offline
Old 26th June 2009, 23:50   #7
Luxauto
Garage: 1993 E34 M5 3.8, diamantshwarz mettalic
I heard about this when I checked my valves. Sure enough, I couldn't tell the difference between the shim I pulled out and the pile of Volvo shims I had, so didnt' have to order any! It's for the volvo red block, 4 cyl OHC, 1975(?)-1995 engines.
Luxauto is offline
Old 30th June 2009, 19:32   #8
First e28 M5
Garage: E28 M5
Valve Adjustment
Hi, I have bunch of M-Cars with S38 Engines. I start doing it by myself and it is very easy.
If you never done it don't scare . I promise you that after the second cylinder you will realize how easy it is! And after you do all valves make sure you go back to the firts two that you have started from and check for you your work done...
Hear is my link: Hope will help you!EURO Classic Motors | Articles
Regard
Anri
First e28 M5 is offline
The Following 4 Users Say Thank You to First e28 M5 For This Useful Post:
davidoli (30th June 2009), IvanDias (1st July 2009), Lantz (1st July 2009), mottati (30th June 2009)
Old 2nd July 2009, 05:05   #9
marekd174
Regard
Anri
I do it myself as well. It's really easy and once you get the hang of it the first time, the next time you do it, it becomes really easy.
ANYONE WITH FUMOTO VALVE malexgcab E39 M5 and E52 Z8 Discussion 46 27th October 2009 03:05
Trying to remove valve shims from tappets Robinson E34 M5 Discussion 2 24th July 2008 22:05
Help me- M88 valve clearances....15 shims reqd farrell E28 M5 Discussion 16 2nd March 2008 13:19
Re-use Old Shims on Brake Pads? Norcal M5 E39 M5 and E52 Z8 Discussion 12 13th December 2005 05:29
Need Education: Teflon Shims chunpng E39 M5 and E52 Z8 Discussion 11 3rd July 2002 19:12
Page generated in 0.12836 seconds with 11 queries
