Hey guys Im rebuilding my diff right now and I wanna plumb in a cooler using a turbowerx oil sump pump and an aluminum oil cooler. My only concern is the size of the cooler. For packaging reasons I want to use a smaller cooler so I can tuck it in the wheelwell. Im thinking about using a 6.25x4.75.2 core for my diff. Any ideas as to if it will be enough for it ?
Im using this pump for it.
Exa-Pump®
The drain plug and fill holes are M22x1.5 threads, so im gunna use an adapter plug that has an AN flared thread on it and use the drain as a supply port and the fill hole as a return port. Im just curious if the small core has enough surface area to effectively cool the diff down. And also if the diff input shaft will be starved for oil by the sump sucking oil from the drain plug. That could be rectified by filling the diff slightly more than usual, just so the input shaft bearing always has a constant submersion with oil.
I just had my factory diff go on me and I do beat on it alot, ex. hard launches, high speeds, rapid acceleration and hard braking, so its a good idea to have something to cool the fluid, I really dont want to have to go thru this again and I always love having peace of mind about my components. This is a peace of mind mod more than anything.
