Old 10th June 2009, 04:32   #1
Lucid3ntr0py
Garage: 1991 M5 brillantrot
Strange sound, please advise
Greetings. I wish my first post was under better circumstances but it's not. I recently picked up a 91 M5 with 68k. Beautiful. I took it to the dealership today to give the complete once over. They looked over it recomended adjusting a rough idle and replacing the shims. I'm fine with that. Today when I bring it home (I'm around 55 miles from the dealership) I hear a very odd sound.
I know describing sounds is almost useless but I'll do the best that I can. It is kind of like a low rattling/burring sound. It isn't high pitched, but doesn't have any exhaust tone to it. It doesn't really sound like a belt either. It is kind of like a marble rolling/getting stuck sound. I can hear it best when I put my head next to the wheel well.
I know it could probably be a bunch of things but I would like to know if there is anyplace I should look. Should I not drive it back to the dealer?
I don't want to hurt this car as she is my DD.
Thanks for the time.
Joe
Lucid3ntr0py is offline
Old 10th June 2009, 19:02   #2
chrisdaph
chrisdaph's Avatar
Garage: 1989 E34 M5 Sebring Grey, 1991 ALPINA E32 B12 Diamantschwartz
First of all, is the idle still rough? Most E34 M5s have a rough idle, something that a grounding kit will usually fix.
Secondly, if your dealer changed the (wheel) shims, the rotor(s) may be rubbing a little on the brake calipers because they were disturbed. Hopefully, he put the correct shims on. Get the car up on a lift and rotate the wheels manually, looking at the brake rotors for any side-to-side movement or rubbing from the calipers.
Chrisdaph:
1984 528e-sold
1988 535i-sold
1990 535i-sold
1994 525i-sold
1997 740iA-sold
1999 740iA-sold
2001 525iT-sold
2001 540iT Sport-sold
2001 740iA Sport-still have-wife won't let me drive it!
2004 745LiA-sold
1989 E34 M5-summer driver
1991 ALPINA E32 B12 5.0 -summer driver as well
2007 FJ Cruiser-winter driver
chrisdaph is offline
Old 11th June 2009, 02:26   #3
Baddie
Garage: M5 Daytona Violet 3.8
Depends how rough the idle is, but they don't idle like a normal car because of the cams needed for 90 bhp/litre without variable timing.
You haven't said if the noise occurred on the way home or on start up after you got home and the car had had time to cool. The air pump kicks in after a cold start to burn excess hydro-carbons in the exhaust (again a result of aggressive cams) before the cat lights up. The sound is as you describe, and shuts off after a few minutes. The air pump is on the right front of the engine, and the noise makes you jump when you haven't heard it before.
I suspect that in relation to idle your dealer was referring to valve shims, which will have nothing to do with your brake discs.
If you focus on quality, you don't need to worry about quantity.
Baddie is offline
Old 11th June 2009, 02:47   #4
plisken
plisken's Avatar
Garage: 95 BMW M5 green, 3.8 6spd
If the noise is on startup, after say 30 seconds or so and lasts, what, about the same, then it is the air pump most likely.
My car has been in the STealers for so long, I am forgetting how it sounds or how long it lasts etc
95 E34 3.8 M5 6spd
87 Capri280 Turbo Technics, +290bhp@17psi [Not Currently For Sale]
83 Capri 2.8injection RIP
93 Mitsubishi Pajero
plisken is offline
Old 11th June 2009, 04:25   #5
mstupp
mstupp's Avatar
Garage: 1993 M5 Avus Blue
If you are anywhere near Newbury, here is an independent shop that knows the M5 well if want to try someone other than the dealer.
Schneller BMW Service & Performance of Rowley MA
Michael
mstupp is offline
Old 11th June 2009, 19:28   #6
Lucid3ntr0py
Thanks for all the replies. Turns out it is a noisy clutch. They replaced the tranny fluid with ?ATF? and now it sounds a little rough. Not so sure that is cool with me.
I am pretty far from Newbury, but I can make a trip for the car. Is there anyone in particular I should talk to?
Thanks again guys.
Old 11th June 2009, 20:16   #7
Baddie
The tranny fluid in the Getrag 280/5 fitted to my car is supposed to be ATF.
Hope you get it fixed easily
Baddie is offline
Old 11th June 2009, 20:25   #8
tcsm
Garage: Black E34 M5
Could it be the infamous input shaft rattle? Does it appear when the car is idling in neutral, but disappear when you put in the clutch?
tcsm is offline
Old 11th June 2009, 21:44   #9
woods
Garage: 91 M5 - Diamantschwartz
If it's the transmission - you can relax a bit. The easy way to test this is that the noise should go away when the clutch is pushed in.
1. It is "normal" for these transmission to rattle a bit due to loose tolerances on the reverse gear shaft (or something like that) and the relatively rough idle. A little rattling does not indicate imminent failure.
2. The rattle probably used to be there, but thicker fluid in your case was just masking/damping it.
If you don't like the noise, switching to a heavier weight gear oil (such as Redline MT90) may reduce the rattle - though it's really only masking it. It may also change the way the transmission shifts (especially when cold). Each box seems to be a little different when it comes to what oil works best. ATF is relatively low vicosity (around 75W I believe) and is what BMW filled it with at the factory.
Cheers.
woods is offline
The Following User Says Thank You to woods For This Useful Post:
Lucid3ntr0py (12th June 2009)
Old 12th June 2009, 03:02   #10
Lucid3ntr0py
Cheers.
1. Yup. It actually becomes prevalent after switching into reverse.
2. I understand how the thicker fluid would mask it, but here is my question: If the lighter fluid causing the clutch ot make noise, which I assume is generated by the vibrations cause some metal on metal shaking, wouldn't the thicker fluid reduce contact and therefore wear?
3.Cool. What do you use in yours?
Strange Exhaust Sound - not CPS 100%Cocoa E39 M5 and E52 Z8 Discussion 9 7th April 2009 02:57
Strange sound, what is about to brake? red_wings05 E39 M5 and E52 Z8 Discussion 7 7th August 2008 22:34
Strange sound ccm241 E39 M5 and E52 Z8 Discussion 18 25th January 2008 01:59
strange buzzing sound? HELP! phillygoat E34 M5 Discussion 11 5th November 2007 20:58
Strange Sound vitaman E39 M5 and E52 Z8 Discussion 1 17th February 2004 02:34
Page generated in 0.21348 seconds with 11 queries
