Originally Posted by Lucid3ntr0py
1. Yup. It actually becomes prevalent after switching into reverse.
2. I understand how the thicker fluid would mask it, but here is my question: If the lighter fluid causing the clutch ot make noise, which I assume is generated by the vibrations cause some metal on metal shaking, wouldn't the thicker fluid reduce contact and therefore wear?
3.Cool. What do you use in yours?
The noise is not the clutch, it's internal to the transmission. It goes away when you push the clutch in because the transmission stops spinning... There should be no noise when in gear and moving at >1500rpm.
The wear issue is debatable in terms of the effect of a heavier fluid on the rest of the transmission. Noise does not necessarily mean there is excessive wear going on....
I use Mobil1 ATF in mine. It rattles audibly at idle when hot but not at all when the fluid is cold. I'll likely try something a little heavier the next time I change it out.
