Old 9th June 2009, 10:34   #1
umetay
Garage: bmw e30 with m5 engine
s38 3.8l flywheel upgrade.
hi everyone..
I was looking at a upgraded flywheel for my s38 3.8l..however I could not manage to find any brand..İs there anyone who has got any idea..
cheers
ulusal
umetay is offline
Old 9th June 2009, 14:14   #2
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Hi,
JB Racing. Excellent.
Avus Blue 6 speed 3.8L E34 ///M5 Sedan
Evolve ECU Remap / Chip | Evolve Carbon Intake | Powerflex Black | Whiteline | Eibach Springs
2001 E39 530iA Sport
Cyrus is offline
Old 9th June 2009, 17:32   #3
93FIM5
Garage: 1993 M5 Black
Originally Posted by Cyrus View Post
Hi,
+1 , I have the JB Racing unit on my 3.6 and its great.
93FIM5 is offline
Old 9th June 2009, 23:59   #4
umetay
thnks guy showever jb only produces single mass flywheels not a dual mass flywheel..therefore it does not work on 3.8 l euro models..
umetay is offline
Old 10th June 2009, 00:21   #5
93FIM5
The 3.6 flywheel will work on the S38B38 you simply have to use the S38B36 clutch and pressure plate, I believe this applies to the 6 speed as well if your car is equipped with it. Rob Levinson at UUC Motorwerks has a M5 3.8 Touring that uses a OEM 3.6 flywheel so if you have any specific questions I would email or call him and Im sure he can point you in the right direction UUC Motorwerks * Ultimate Performance Fine-Tuning. Good luck.
93FIM5 is offline
Old 10th June 2009, 10:04   #6
umetay
yes I know the application of 3.6 clutch,..however ı have already bought a new set of clutch set for 3.8l and a sachs sre sineterd plate clutch(organic) as well..therefore I only need a lightened fly wheel which is compatible with 3.8 oem parts..
thanks
umetay is offline
Old 10th June 2009, 15:39   #7
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
thanks
Using a sintered plate on a dual mass flywheel is a pretty stupid idea, don't you think?
A dual mass flywheel would last about 10 minutes. And a dual-mass is just that. Dual-mass. So lightweight dual-mass would be the same as dry rain or wet fire. You could skim the outer half of the dual mass but IF shavings eacht the rubber core the flywheel is dead. Just convert to 3.6 or JB, considering the price of a JB the 3.6 clutch is pocketchange.
Dragracing a BMW is like taking Jessica Alba fishing. Some might considering it fun, but think of what they missed....
Stevie is offline
Old 10th June 2009, 16:07   #8
93FIM5
Well put Stevie.
93FIM5 is offline
Old 10th June 2009, 16:19   #9
umetay
Dear Stevie
this clutch is produced by sachs and it is called performance clutch disc..with special organic friction material...it is not a common sinterbelag which is metal plated..
umetay is offline
Old 11th June 2009, 01:05   #10
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Send a message via ICQ to pspassos Send a message via MSN to pspassos Send a message via Skype™ to pspassos
man.... there is NO other dual mass compatible one diferent from the OEM.... if you want, I can sell you my used duall mass flywhell so you can try to make it lighter.... but there is none of the shelf.... the way to go is 3.6 complete clutch kit + fly.... if you dont want it, forget upgrading and go OEM...
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline
New or Used Flywheel? JML M5 E39 M5 and E52 Z8 Discussion 16 28th February 2008 15:45
Flywheel bay E34 M5 Discussion 5 16th November 2005 02:12
Dual Mass Flywheel .vs. Lightweight Flywheel--What Performance Differences Do You See Anita E39 M5 and E52 Z8 Discussion 33 15th February 2005 17:06
Flywheel upgrade? AlpinaB8 ALPINABoard.com | BMW Alpina Discussion 2 15th December 2004 21:40
Flywheel w/o software upgrade? SandBeast E39 M5 and E52 Z8 Discussion 10 21st August 2004 18:03
Page generated in 0.13477 seconds with 11 queries
