Originally Posted by umetay
thanks guys..it seems that I am going to use oem one and may be try to enlight it..
I think there is very little to win on that. You propably neither feel nor can measure any difference with that mod as the construction of the dual mass flywheel as such will keep the weight relatively high. The 3,6 fly is under half the weight of the dual mass wheel, and that you can feel(just) most obvious is the more rapid response/fall in the revs when you blip the throttle.
Good luck anyway
Sakke
