Old 8th June 2009, 16:32   #1
Crash & Burn
Crash & Burn's Avatar
Garage: E34 M5-Touring, Fjord Grau
Send a message via Skype™ to Crash & Burn
Replacing throttle cable
Small question:
My throttle cable is about to give in (break). is it easy to replace the cable?
Do I need to remove the master brake cylinder or anything? Seems awfully narrow where the cable is going!
Any tips would help....
1995 Fjord Grau 3.8 sixspeed Touring
Crash & Burn is offline
Old 8th June 2009, 20:24   #2
Rapamaha
Garage: -92 M5 3.8 daytonaviolet
try to lift and move water valves away so that You'll see where throttle cable goes through the firewall
Rapamaha is offline
Old 8th June 2009, 20:30   #3
WillM5
WillM5's Avatar
Garage: E34 M5 Diamantenschwarz
Just did this a couple weeks ago. Unbolt and lift up the water valves as stated above, and have alot of patience. You will scrap your hand and it will take a while. Just be patient and it ll clip in.
Engine : S38B36 - MM 296° Rally Intake Cam, E28 Exhaust Cam (248°), Race Port (31mm) , High Lift Valve Springs, High Performance Rings, Refreshed Bottom End, Port Matched Throttle Bodies, BMC CDA Intake
Exhaust : Wrapped Headers, Straight Exhaust, Supersprint Resonator, Eisenmann Race Exhaust
Suspension : H&R Sport Springs, Koni Yellows, M5T Rear Sway Bar, Racing King Rear Subframe Inserts
Exhaust Clip http://www.youtube.com/watch?v=I3CSE39PTCA
WillM5 is offline
Old 8th June 2009, 22:42   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i did mine while replacing the vacuum and water hoses under the plenum, so i had the plenum off (not a difficult job in itself) so there was plenty of space.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 9th June 2009, 19:38   #5
JohnR
JohnR's Avatar
Garage: 1993 M5 3.8 Black
I tied a string to the old one before removing. Thats all I had to do.
JohnR
JohnR is offline
Old 9th June 2009, 19:58   #6
Crash & Burn
I reckon you remove it from the enginebay after first loosening the cable from the pedal?
Old 9th June 2009, 20:32   #7
AndyHudds
Garage: 1993 E34 M5, (think calypso red)
Hi there all
I did our andys earlier this year, cost 20 quid from BMW, was a piece of cake, the most difficult part was getting the old cable out, there is a square hole behind the accelerator pedal where the new cable clips in and getting the square plastic clip out is a pain, just clip it out with a flat bladed screw driver
The aforementioned water hoses valves are in the way too for threading the cable round the back of the dashboard but even if youve got big hands (like me) you can still reach down to guide it through the hole round the bottom of the dash.
Took around 30 minutes in the freezing cold january weather we had
best regards
James
AndyHudds is offline
The Following User Says Thank You to AndyHudds For This Useful Post:
davidoli (9th June 2009)
Old 9th June 2009, 23:26   #8
corneredge
Garage: 1994 M5 3.8L Avus Blue
How man miles should I expect from a throttle cable? Are they a common problem? do you think they broke due to wear or adjustment too tight? Just wondering when to add it to the maintenance list.
Thanks,
Russ
corneredge is offline
Old 10th June 2009, 00:08   #9
mottati
mottati's Avatar
Thanks,
Russ
i did my 3/90 production car at 150k miles, with coolant hoses, belts, vacuum lines etc. Was obviously frayed/worn.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Using Throttle Cable from another vehicle? IAmCman E34 M5 Discussion 2 29th October 2008 07:34
Replacing flywheel when replacing clutch? kosmo E39 M5 and E52 Z8 Discussion 18 6th March 2007 01:26
How to adjust throttle cable karlcchen E34 M5 Discussion 4 18th July 2006 22:37
What is the second cable, beside the throttle cable for? plisken E34 M5 Discussion 2 29th May 2004 17:15
8 Throttle bodies vs Dual Throttle bodies, Dinan Myth? MIB E39 M5 and E52 Z8 Discussion 6 26th December 2003 17:33
Page generated in 0.13817 seconds with 11 queries
