Old 8th June 2009, 01:37   #1
Elekta
Elekta's Avatar
Garage: BL01908 Elekta M5T Silber Metallic
jacking blocks question
What do you use when you don't use the oem car jack? I have a 3 ton shack from Sears and the round 4" cup can't really do much but trash the MTech skirt while it jacks up the car. I am looking to remove the right front wheel to check the acceleration sensor..try and get it ID'd or fired up before a road trip to Marathon, TX (6 hour road trip out West).
If you don't jack it up from the jacking point where else would you put it before lifting the car.
Wife has gone to FL with the kids, and I actually have some time to DIY for a few days. (which would translate into take it apart and then find someone to help put it back together - w/o a spouse editorializing
Sadly, yes I am this lame, but if I can sort this sensor issue, I won't have to deal with my buddy asking me every 5 miles or so what the EDC error message is all about.
Elekta is offline
Old 8th June 2009, 05:07   #2
Konfused Pete
Konfused Pete's Avatar
Garage: Black '90 e34 M5
Get the jack right in the middle of the front subframe. it'll easily lift the whole front.
also there is a big engine carrier member running half the length of the car starting at the firewall either side of the engine.
as per pic:
Konfused Pete is offline
The Following 2 Users Say Thank You to Konfused Pete For This Useful Post:
dscam (9th June 2009), IvanDias (9th June 2009)
Old 8th June 2009, 08:04   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
nice looking undercarriage Pete!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 8th June 2009, 09:37   #4
Konfused Pete
not mine. i can't even remember where i found that pic. i thought it was a good one though!
Old 8th June 2009, 10:29   #5
Lantz
Lantz's Avatar
Garage: BMW M5 E34 Granitsilber Metallic 3.8
I usually use the chassi-rails (also shown in the pic) when changing my front tyres. Works a treat and much easier than using the OEM jack.
Lantz
Lantz is offline
Old 8th June 2009, 15:55   #6
corneredge
Garage: 1994 M5 3.8L Avus Blue
You can also use a 2x4 peice of wood on the sill where the factor jack would go. this protects the sill and provides a wider surface area. Just be careful about slippage. I use this to jack with my conventional jack, and then use the frame rails for the jack stands.
corneredge is offline
Old 8th June 2009, 16:19   #7
Elekta
Elekta's Avatar
gah,
what a great pic. thank you.
so-looking in the upper left at the front right wheel and strut...that line is the brake line of course. The acceleration sensor is out of view up above the disc? Is it going to have a little screw cap with a wire coming out of it?
That's project one, and then replacing the main windshield washer pump. My fingers are too fat to pinch that connector...won't needle nose destroy it? Will the pump and connector come out together after I disco the hose?
wife and kids left for Naples,FL yesterday. This is rare opportunity to actually do something myself for once. I have a 50th bday party to attend at Marathon, TX
street view google maps is so cool.
290>I-10 is the shortest distance with legal 80 mph limits, but if I had an excuse to get to san antonio, taking 90 thru hondo and uvalde to del rio is much more scenic in the wide open spaces type driving
I-10 is 394 miles 6 hours 24
90 is 407 miles. 7 hours 28
I know it can be done in 5 hours if you eat lunch in the car and fast fuel.
Elekta is offline
Old 8th June 2009, 17:45   #8
Ratty
Ratty's Avatar
Garage: 1991 E34 M5 Jet Black
I drive mine up onto two blocks of wood about 2 inches high, one under
each front wheel.. then the trolley jack goes straight under anywhere you want.
The Oem jack always seems to risk pushing the door panel in when the car's lowered
Ratty is offline
Old 9th June 2009, 00:19   #9
dscam
Garage: E34 M5 3.8 - Daytona Violet
Excellent picture and explanations here! A silly question, but those arms on the four post lift look as though they are on the standard jacking point spots - surely this is likely to cause damage to the side skirts in the same way a trolley jack would on these points?
dscam is offline
Old 9th June 2009, 05:55   #10
Konfused Pete
To me they look like they're on the actual sill / floor pan seam - which is far worse. good way to simultaneously mangle the seam and destroy the pvc underseal and paint.
Nav blocks blueaudis4 E39 M5 and E52 Z8 Discussion 2 10th May 2008 07:17
A Couple of Salt Blocks... Wayward E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 14th April 2006 23:32
M5 Crystal Blocks FastFwd E39 M5 and E52 Z8 Discussion 485 13th April 2006 09:34
Transit Blocks still Fitted!!!!!!!! Fumesy E39 M5 and E52 Z8 Discussion 8 11th April 2006 23:17
Page generated in 0.17995 seconds with 11 queries
