Old 8th June 2009, 23:10   #11
Ferrari-Bmw
Garage: Alpina B10 Biturbo Ferrari Yellow
Originally Posted by Eku View Post
Hello Ferrari-BMW!
So are you still running original engine management system?? Is this somekind of chip tuning or have changed to adjustable management system??
Yes ,, this is an induvidual, tuning by Mr.X
yes the oem ECU,, just another reprogrammed chip
nice done and works,, this is a simple job (he told me )
and i like it ,, no more dirty MAF
Sveinbjörn Hrafnsson
E30 CABRIO S3 8B38
ALPINA B10 BITURBO 346 @ 507
www.123.is/alpina
Ferrari-Bmw is offline
Old 9th June 2009, 10:25   #12
Ferrari-Bmw
Here is an explaination of what ALPHA-N actually is ,,,,, from Mr.X
I have been working with race cars all my life and in racing we like to keep thinges as simple as possible and let as few sensors as possible be involved in correcting the base map made for the car!
By doing it that way we have less chance of sensor errors taking us out of the race.. this doesnt mean that we dont have a **** load of sensors fitted to the engine!! We have almost everything you can think of but only fitted for monitoring and logging..
Alpha is the term of the first used factor to calculate the engine load.. and that ofcause is the throttle angle! the "N" is the engineering term of revs. so alpha-n is the throttle angle vs. rpm in a 3d load map that will replace the messured values from the missing mass air flow sensor(MAF)..
The Mss52 ECU have like alot of other ECUs a replacement tabel if the MAF goes bad! the problem is just, the acctual diagnostic function for entering that tabel is really bad so the car normaly runs like **** when they dont work... that doesnt mean if you just disconnect them you would have a nice running car.. because the manufactores like BMW sets the replacement tabel for the MAF low or high so the car either runs rich or lean! but it will still allow the customer to get to the workshop!...
The main reason for the MAF is the emission aproval test.. this test is very hard to pass for the manufactors, and with more polution the more tax pr. produced car.. thats why you see some manufactors use the same engine in models with different preformance!! they save money due to the lower emissions...
The MAF function for the emissions is to give the ECU a precise information of how much air thats going thrugh the engine! so it can make sure the emissons values are 100% at all times no mather engine condition!!
THIS doesnt mean that your car will make the birds fall of the trees when you pass in your MAF less M5, because... during the emission test the engineers block 85% of the airfilter and change 50% of the engine oil to some black thick ****, then they drive around to see if everyting is still ok!
The rule is if 2 customers buy a car the same time and A makes all the services the next 60000miles and B only change the oil 2 times in 60000miles... the emission rate from the cars must be the same!! and you cant compensate for that unless you use a airmass meter to help you out!! or a mapsensor like the CSL so the ecu knows the state of the engine... so if you do run MAF less keep your services..
When you fit a SC to a E39 M5 the poor quality of the MAF sensors can do alot of mess of the base mapping of the car.. and then the companys who makes the SC kits will have big problems with their kits because none of the cars run like the car they used for developing the software for the kit.. thats why the easy sollution is the MAF delete!! so whats done is just disconnecting the airmass sensor take care of the error code shown by the ECU for no connection to the MAF and then you start to tune the replacement tabel and the fuel maps...
alot of tuners dont change the replacement map for the MAF and it will work ok too with the from BMW preset values, and the main reason for this is the car isnt fitted with wideband sensors!((thats another story) E39 M5 can acctualy be converted to wideband sensor i have done it on 3 engines fitted in e36 and e46 chassis used for racing! the cars are N/A and MAF less.. i make them run close loop(full lambda control) at all times and it works very nice.. so it can be done
E30 CABRIO S3 8B38
www.123.is/alpina
Old 9th June 2009, 20:49   #13
Eku
Garage: BMW M5 3.8 -92 silver
Hello again , here is few questions:
Is this somekind of "power chip" also?? (like unichip, wetterauer etc). Or is it
just meant removing the MAF? So is there more power and torque also available with this chip??
Do i have to get my car tuned in dynoservice? Or is this universal chip that fits to all S38B38?
Can topspeed limeter be removed complete?
Eku
Eku is offline
Old 9th June 2009, 22:06   #14
Ferrari-Bmw
EKU,,,
the V-MAX delete is no problem,,
I dont think Mr.X do international chip program,,
all cars have a personal and induvidual tuning by him self,,
he says tha a engine like S38 is not that good that you can put ,, these universal chip ,, and be sure you get would you bought and thought it was gonna be,,
he made the chip for my engine .. from a empty one
E30 CABRIO S3 8B38
www.123.is/alpina
Old Today, 00:03   #15
Eku
Hello
Did you remove MAF completely or is it still in place??
And if you did, did you notice any performance gains???
Eku
Eku is offline
Old Today, 00:53   #16
Ferrari-Bmw
Hello
Eku
The feeling is that the car is quicker,,, i dont know ,,, in real
this is a heavy car,, but i went 13.28 -> 1/4 @ 107 mph
the maf is still in place,, i am working on a pipe in replacement ,, i will use oem intake airbox
E30 CABRIO S3 8B38
www.123.is/alpina
Unread Today, 12:14   #17
Eku
Hello
Let me know when you have removed MAF completely, is it feeling different. Or do you have snow on the ground on Iceland like we have here in Finland???
Eku
Eku is offline
Unread Today, 12:33   #18
Ferrari-Bmw
Hello
Eku
Reykjavík is on 64°N ,, the same degree as Trondheim in Norway
CABRIO is in the GARAGE
I will post when i am finished ,, taking the MAF out of the intake hose
E30 CABRIO S3 8B38
www.123.is/alpina
Deleted dmc For Sale or Wanted 0 12th November 2004 15:50
M5 E60 Bangle deleted Humanoid E60 M5 and E61 M5 Touring Discussion 22 15th March 2004 21:17
Page generated in 0.10635 seconds with 11 queries
