Old 6th June 2009, 10:40   #1
First e28 M5
Garage: E28 M5
Oppinion is needed. S38-B36 vs S38 B38. Thanks
Hi S38 mates,
I am building a S38 B38 into E30 M3...
My only question is:
If I fit 3.6 Single Flywheel/cluch and replace the original Dual Mass Flywheel from the 3.8, am I going to damage something on the engine, crank shaft ? Or this dual mass fly wheel is made for more comfort driving to eliminate vibrations?
The reason I want to upgrade is because I have read some 3.6 owners did upgrade and they are saying that the Engine is reving much faster than Dual mass fly wheel.
I only wander if I do this change will I cause damage on the Cranck Shaft, Engine?
Anri
First e28 M5 is offline
Old 6th June 2009, 16:07   #2
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Send a message via ICQ to pspassos Send a message via MSN to pspassos Send a message via Skype™ to pspassos
no damage at all my friend..... its just for confort....
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline
Old 6th June 2009, 23:20   #3
Dragonsi
Garage: e34 m5
Pics!
Dragonsi is offline
Old 7th June 2009, 17:08   #4
Ferrari-Bmw
Garage: Alpina B10 Biturbo Ferrari Yellow
Hi,,
lovly engine choice,,
BUT :::::: i guess that B38 is the engine that is more rare than any other
S- engine in the STATES ??
Or am i wrong
Sveinbjörn Hrafnsson
E30 CABRIO S3 8B38
ALPINA B10 BITURBO 346 @ 507
www.123.is/alpina
Ferrari-Bmw is offline
Old 7th June 2009, 17:34   #5
First e28 M5
Garage: E28 M5
Yes if you guys see the car my German friend destroyed you will claim me as a Criminal (Avus Blue 94 car never been in any tip of accident ).
Yes S38-B38 is RARE engine hear in US and not to mention in E30 M3 car.
Never done it so far..
Back to my post. I need more opinions for my Question. Thanks to "pspassos" for the reply!
Anri
Old 7th June 2009, 17:42   #6
Ferrari-Bmw
Frank Fahay did a B36 conversion in a white E30 M3 some years ago,,
he said,, that it was a unbeliveble more complexed vs S50
I would contact him if i was you
Frank Fahey Motorsports Home
He have a wonderful M1 by himself
truly a stunning car
E30 CABRIO S3 8B38
www.123.is/alpina
Old 7th June 2009, 18:00   #7
First e28 M5
Garage: E28 M5
Yes I know his car and his work. I am not impressed from his project its not done right! ! ! Yes he has lovely E26 M1 car.
LET'S NOT DESTROY WHIT OFF TOPIC MY ORIGINAL POST FOR THE S38-B38 CLUTCH QUESTION LIKE THE OTHER I HAD PLEASE !
Anri
Old 7th June 2009, 18:22   #8
MM-5
MM-5's Avatar
Garage: BMW M5 3.8 1992 Daytona Violet
Hi Anri!
I have done this modification to S38B38. I have 3.6 single mass flywheel and Sachs SRE clutchkit. I can recommend this modification. There is weight reduction in total weight and more importantly in rotational weight. Engine revs more freely and no problems with gearbox noise with this flywheel. Some lighter flywheels can cause gearbox noises.
EDIT: Remember to change the 3.6 flywheel bolts too when doing this change. They are different lenght.
Best Regards, Janne.
MM-5 is offline
Old 7th June 2009, 18:47   #9
First e28 M5
Garage: E28 M5
Thanks MM-5,
I appreciate your reply and experience. If I am not mistaking my self S38-B35 E28 M5- E24 M6 the whole clutch/plate is the same as S38 B36 3.6 ???
I will get the same setting as yours.
Anri
Oppinion is needed S38-B38 Headers on S38-B35 First e28 M5 E34 M5 Discussion 2 15th May 2009 18:45
Oppinion is needed m88/3 headers vs s38-b38 thanks First e28 M5 E34 M5 Discussion 5 8th April 2009 07:40
Oppinion is needed about EXHAUST system! Thanks First e28 M5 E34 M5 Discussion 2 15th March 2009 19:21
M5 3.8 Speed limiter Question Oppinion is Needed First e28 M5 E34 M5 Discussion 1 27th January 2009 10:28
NEED HELP PLEASE S54 VS S38B38 OPPINION First e28 M5 E34 M5 Discussion 3 29th February 2008 15:40
Page generated in 0.12496 seconds with 11 queries
