Old 1st June 2009, 15:21   #21
WillM5
WillM5's Avatar
Garage: E34 M5 Diamantenschwarz
On the speedo. Fastest ive been with the GPS with me is 169 MPH, which was around 270 km/h.
Engine : S38B36 - MM 296° Rally Intake Cam, E28 Exhaust Cam (248°), Race Port (31mm) , High Lift Valve Springs, High Performance Rings, Refreshed Bottom End, Port Matched Throttle Bodies, BMC CDA Intake
Exhaust : Wrapped Headers, Straight Exhaust, Supersprint Resonator, Eisenmann Race Exhaust
Suspension : H&R Sport Springs, Koni Yellows, M5T Rear Sway Bar, Racing King Rear Subframe Inserts
Exhaust Clip http://www.youtube.com/watch?v=I3CSE39PTCA
WillM5 is offline
Old 1st June 2009, 15:53   #22
Sebring NL
Sebring NL's Avatar
No problem to have high speeds on any E34.
So Mert, how is the engine building going?
wout
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 1st June 2009, 16:11   #23
Jon Baker
Jon Baker's Avatar
Garage: E34 M5 3.8 - Daytona Violet
Fastest I've seen on the clock was 172mph, car felt great at this speed, especially as the V8 RS4 behind me was slowly becoming a smaller and smaller dot....
More recently Calypso managed 161mph (GPS) with Finaledition at the wheel, this car felt slightly more nervous at top speed but nothing that makes you not want to go there again.
Jon Baker is offline
Old 1st June 2009, 16:35   #24
Ferrari-Bmw
Garage: Alpina B10 Biturbo Ferrari Yellow
Gentlemen,,
these numbers are indeed impressive ,,,,,,
Sveinbjörn Hrafnsson
E30 CABRIO S3 8B38
ALPINA B10 BITURBO 346 @ 507
www.123.is/alpina
Ferrari-Bmw is offline
Old 1st June 2009, 17:23   #25
Mmm-Five
Fastest my old 6-speed 3.8 would go was an indicated 176mph in 5th which was showing 167mph on the GPS.
BTW, it also felt more stable at higher speeds (in a straight line) than the Z4 does.
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 1st June 2009, 18:31   #26
Jon Baker
Jon Baker's Avatar
Based on GPS speed that is more or less the limiter in 5th, only another 2.65mph to go. Thats good going Tony, but you always were a nutter!!
What have you had out of the Z4...?
Old 1st June 2009, 19:19   #27
Mmm-Five
Only been to 150mph* on the road so far (and 120mph at Oulton Park), but that's due to me being on UK public roads. The car still seems comfortable cruising at 100mph though and gets better fuel economy at that speed than it does at 90mph (must be something to do with the torque curve?).
Can't wait to get to an autobahn to see if the 5th gear workaround is the same on the Z4 as it is on the M5 (in fact I even thought about driving to work in Hamburg last week just to do so - until I realised how much further Hamburg was).
* may or may not be true, so don't try to do me for admitting speeding on UK roads
Mmm-Five is offline
Old 2nd June 2009, 15:47   #28
Jon Baker
Jon Baker's Avatar
Just do it Tony, I drove to Rome for exactly the same reason!! Although in a 1.9 diesel Astra it wasn't quite the same.....
Old 2nd June 2009, 17:29   #29
Sebring NL
Sebring NL's Avatar
for the record, when I had my car for two months, I did a GPS 272 km'h on the A31 Bottrop-Gronau and 270 GPS on the way back. It was quite slow for me, since I made 308 km'h there with my Esprit when I was 19.
3.6, ACS chip.
Old 2nd June 2009, 18:07   #30
Jon Baker
Jon Baker's Avatar
3.6, ACS chip.
That must be a record GPS speed for a 3.6...
And now i think of it, also for the Esprit as I am assuming it wasn't a V8.
Page generated in 0.13370 seconds with 10 queries
