Old 30th May 2009, 07:41   #1
Gerg
Gerg's Avatar
Garage: '91 M5
EDC Not Active Question
The light for the S/P switch stopped working and then I started getting the EDC not active warning. This has happened a couple of times now. When I take it to the shop they use a scanner to clear the fault. Then it operates fine for a month or so. The fault I'm getting is "front acceleration sensor". Where is it and is it easy to change?
It's so nice when it's working.
Greg S.
'95 M5 six speed Sold
B10 Biturbo #362 Sold
'91 M5
"92 M5T #001
'93 M5T DV
"84 635CSI Euro
Gerg is offline
Old 31st May 2009, 12:01   #2
Baddie
Garage: M5 Daytona Violet 3.8
I'd check the wiring to the sensor before replacing it - wiring looms are a reliability suspect now, especially underbonnet where the heat hardens it even more than age and vibration already have elsewhere in the car.
If you focus on quality, you don't need to worry about quantity.
Baddie is offline
The Following User Says Thank You to Baddie For This Useful Post:
Gerg (31st May 2009)
Old 31st May 2009, 19:57   #3
M5Freestyle
Garage: M5
Agreed. Check the loom first
M5Freestyle is offline
Old 31st May 2009, 23:58   #4
Elekta
Elekta's Avatar
Garage: BL01908 Elekta M5T Silber Metallic
front right wheel arch. I still haven't taken mine off and have the same issue. When you get yours off, please read out the pn will you? It may need to be replaced with the sensor used in the back. It's a $300 part and you want to get the right one. If you have your camera handy when you do this it would be great help. I am avoiding my car like teenager with a term paper. I am so lame.
Elekta is offline
Old 8th June 2009, 21:17   #5
Elekta
Elekta's Avatar
Is this it? Farrell? Faz? Davidoli? Woot? I can't find the pn in Real OEM
pn 1181291
MBB BSB 89A
20-95
Elekta is offline
Old 8th June 2009, 21:22   #6
Gerg
Gerg's Avatar
Garage: '91 M5
Thanks for the info. My EDC has been working fine since resetting it so I haven't changes the sensor.
'91 M5
"92 M5T #001
'93 M5T DV
"84 635CSI Euro
Gerg is offline
Old 8th June 2009, 21:27   #7
Elekta
Elekta's Avatar
I can't find the pn in real oem, so I don't even know if this is the correct piece. Did you get the dealer to reset your codes?
... well I called the dealer and they told me the new pn was
37141179832
but they never said anything about an upgraded part, just the upgraded number..
$297.38 1-2 weeks delivery. How can I test my sensor? I am going to clean it up real good and put it back on. The dealer wanted $116 to clear the fault codes...what a jip
Elekta is offline
Old 8th June 2009, 21:57   #8
Gerg
Gerg's Avatar
Garage: '91 M5
My son works for a BMW-Porsche-Audi shop. I'll usually stop by at around noon and buy him lunch in exchange for resetting my codes. It might be a good idea to develop a friendship with a local indie that has a scanner.
'91 M5
"92 M5T #001
'93 M5T DV
"84 635CSI Euro
Gerg is offline
Old 8th June 2009, 22:20   #9
Elekta
Elekta's Avatar
do the fault codes have to be reset to get the EDC working again?
Elekta is offline
Old 8th June 2009, 22:43   #10
Gerg
Gerg's Avatar
Garage: '91 M5
Yes. He would scan my car and find the fault. Then he hits a fault reset button and the S/P switch lights up and it works fine.
'91 M5
"92 M5T #001
'93 M5T DV
"84 635CSI Euro
Gerg is offline
2008 X5 Question: Active Steering MEnthusiast X5 and X6 Forum 12 5th March 2008 07:21
EDC not active kurt44 E34 M5 Discussion 3 27th May 2006 16:42
Active cruise control question ELEVENS Off Topic Forum 0 12th October 2005 02:49
Question about Active Seat option - can you help? Ashok Arora E60 M5 and E61 M5 Touring Discussion 6 11th August 2004 21:27
Question about Active Autowerke CAI M5Kid E39 M5 and E52 Z8 Discussion 19 8th August 2003 18:15
Page generated in 0.13955 seconds with 11 queries
