Old 30th June 2009, 11:38   #81
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
Forgiveness is easier to obtain than permission....
DaveW is offline
The Following User Says Thank You to DaveW For This Useful Post:
Geach (30th June 2009)
Old 30th June 2009, 13:09   #82
Steve Mac
Steve Mac's Avatar
Garage: 2001 M5 Le mans
So so very true
Steve Mac
_________________
If knowledge is power,,,how brainy are my Baby`s
2001 Le Mans beast ///M5
1995 Fjord ***** ///M5
2002 Black Beauty 320i Sport!!
decisions decisions
Steve Mac is offline
Old 30th June 2009, 15:45   #83
davidoli
Forgetting is the hard part .........
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 3rd July 2009, 18:07   #84
Dan Kelly
Garage: E34 M5 Sterling Silver
A few items cleaned and ready to be fitted...
'90 E34 M5 3.6 Sterling Silver
'03 E39 540i Sport Touring Mora Mettalic
'95 E34 525i Petrol Mica SOLD
'05 KTM 990 superduke
Dan Kelly is offline
Old 3rd July 2009, 18:14   #85
davidoli
Lovely .....those throttle bodies look like new !
You must be aching with excitment Dan !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 3rd July 2009, 20:58   #86
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Wow that is beautiful, congratulations.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 4th July 2009, 12:47   #87
Dan Kelly
Things are coming along nicely.
One of the problems we've encountered was that the EGR pipes were all fractured around their mounting plates and replacing them is an expensive business (£428+VAT). Faz suggested we could delete the system as it won't effect emissions tests as they are carried out at present, I had some concerns about the rules being changed in the future so it was important that the deletion was reversible. The mounting plates were cut off the pipes and welded up (TIG as they're stainless steel) and re-fitted to the manifold. The air pump stays as it tensions one of the belts.
It seemed sensible to send the injectors off to be tested, cleaned and overhauled. Even though to fueling seemed great on the car prior to the failure all the injectors were down around 10%. After cleaning and having new nozzles fitted they are back up to full efficiency. Well worth doing for £25 each. New injectors are £100 each.
Most of the engine is built now and will hopefully be going back in the car next week. There are still a few jobs to do. With the engine out its a good time to give the engine bay a thorough de-grease and clean up, we're going to replace the fan blower motor as its a difficult job with the engine in situ and knowing my luck it would die a week after the engine was back in.
Getting really excited now
Old 4th July 2009, 13:43   #88
davidoli
I've got a set of those EGR pipes for future reference .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
The Following User Says Thank You to davidoli For This Useful Post:
Dan Kelly (4th July 2009)
Old 4th July 2009, 14:17   #89
raymondw
raymondw's Avatar
Hello Dan,
The new engine looks great and it is good to see an E34S being revived proffesionally with reliability and longevety in mind.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
Old 4th July 2009, 18:31   #90
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Send a message via ICQ to pspassos Send a message via MSN to pspassos Send a message via Skype™ to pspassos
by removing the EGR pipes, does any error appears?
I have my engine out nowadays too, and was thinking about removing EGR as well...
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline
My almost disaster, Oil everywhere. Rate39d M E39 M5 and E52 Z8 Discussion 5 4th June 2008 20:48
DISASTER!!!...... BANKROBBER E34 M5 Discussion 99 4th December 2007 16:38
My M5 Disaster!! Mickmoll E60 M5 and E61 M5 Touring Discussion 4 20th August 2005 02:22
M5 Disaster Streak MJ E39 M5 and E52 Z8 Discussion 19 24th July 2003 23:37
Page generated in 0.14331 seconds with 12 queries
