Old 28th June 2009, 14:17   #71
raymondw
raymondw's Avatar
Hi Dan,
That engine looks gorgeous. Knowing Faz his attention to detail, I am confident you will be very satisfied with teh final result.
I do have some questions/ remarks though.
1: Do you still have the old engine ? It does have a significant core charge.
2: You mention the oil pump as the most likely cause, but has that been investigated ? Oil pumps normally are rugged parts. They can loose efficiency by clogged oil-debrie residu. It is interesting to see some pictures of the internal parts of your old oil-pump.
3: I see that the new engine is not supplied with a new crankshaft hub. It is not that expensive and it is wise to replace it.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
Old 28th June 2009, 15:05   #72
Dan Kelly
Garage: E34 M5 Sterling Silver
Hi Raymond.
We will be sending the old engine back to BMW, as you say the core charge is significant - around £2k.
We are suspecting oil pump failure as both the oil filter and canister were very dry, suggesting the oil was not being retuned to it. The engine oil had a lot of metal particles in it when the sump was drained. Also when the failure occurred I noticed the oil temperature rising sharply just before it seized. Interestingly The oil light didn't come on and there was no oil pressure warning on the check control. I don't know if a sensor was faulty. There are of course many other potential causes of the failure, I suspect we will only know for sure when the engine is opened.
I'm leaving Faz in charge of assessing the serviceability of the ancillary parts that will be re-used, I know the crank hub is of the later more reliable type. I don't want to put anything 'suspect' back on the car but I've already ordered around £500 worth of parts to be replaced and unfortunately I don't have unlimited resources for this job.
'90 E34 M5 3.6 Sterling Silver
'03 E39 540i Sport Touring Mora Mettalic
'95 E34 525i Petrol Mica SOLD
'05 KTM 990 superduke
Dan Kelly is offline
Old 28th June 2009, 16:49   #73
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....waking up
Hi Dan,
Thanks for being so candid. I've been following this thread closely as my engine also went pop a while ago.
Done a bit of agonising over the last 18 months, but I'm pretty certain the route you have taken would not be possible for me.
I'll post what my rebuild costs when it's finished.
But so far -
2000euro complete replacement engine, came with 1000e worth of new parts - timing cain etc, oil pump, head gasket, head studs, various other gaskets, nuts bolts, seals etc.
1600e - 6 new Mahle max size pistons and rebore(block was not as good as anticipated)
Costs to come - new bearing shells, dizzy cap rotor etc, vac hoses, valve and head work.
total labour will be about 3000 euro
ouch! with more to come.
Although I have already sold on one set of TBs - 350e and hopefully the extra crank, 11 std pistons & rods and maybe damaged block and head may recoup some of the outlay.
Nasty business this engine going pop pallava!
Look on the bright side, if I don't drive it for a year (2 years) the engine rebuild will pay for itself.(I'll make a profit!!).
GoneAgain is offline
Old 28th June 2009, 21:16   #74
raymondw
raymondw's Avatar
Hi Terry,
Yes I know. My M88/3 engine rebuild:
Set of (six) new Mahle pistons (first oversize, 93,55mm): Euro 1500
Set of (twelve) new intake valves and (twelve new exhaust valves: Euro 1400
New gasket sets (cylinder head and short engine): Euro 430
New timing chain, tensioner rails, sprockets, hub etc: Euro 800
Set of new main-and rod bearings +nuts, bolts etc: Euro 500
Set of new valve springs: Euro 350
Nuts and bolts for the cylinder head: Euro 300
Overhaul cost cylinder head: Euro 1500 (labour and machining)
Overhaul cost of short engine: Euro 1000
Assembly cost: Euro 500
Total cost engine rebuild: ~8k Euro.
New clutch etc: Euro 400
New waterpump, new position sensors etc: Euro 500
Various small parts including engine and gearbox mounts: Euro 500
Totaling 9400 Euro.
Raymond
raymondw is offline
Old 28th June 2009, 23:56   #75
Geach
Geach's Avatar
Garage: 1990 e34 M5 Sebring grey
I have never added up the total cost of my rebuild(s),I have a rough idea of course but always stuck the invoices straight into my cars history file,was too afraid! a,of the costs and b,the mrs seeing them!
Dan.
'90 M5- Sebring Grey
Geach is offline
Old 29th June 2009, 00:21   #76
GoneAgain
GoneAgain's Avatar
Ray - been following that thread closely too!
Dan - I feel the same about all that I've spent too. Multiples of what I paid for the car! And when i bought it I thought that if it started getting expensive I'd just get rid.....hah! I got the fever bad!
Old 29th June 2009, 00:55   #77
erikm54life
erikm54life's Avatar
Garage: '93 Granite Silver E34 M5 Touring
Well done Dan ! I think you've chosen a very admirable route.
If my engine were to go pop...funds permitting ( what else would permit ? !! ) I'd do the same.
The thought of a spanking new engine in one of these cars is pure bliss.
I'm still playing the lottery...if any winnings come my way I'll buy one to stare at until the evil date comes !
Well done...very well done !!
erikm54life is offline
Old 29th June 2009, 15:28   #78
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
A very interesting thread indeed and I sympathise with the costs as at Christmas I had a full rebuild of my E30 M3 S14 2.3 with rebore and new pistons to be sure. Admittedly I did go down the optional tuning route as well with Schrick Cams, Carbon intake and plenum, Alpha N etc but the costs are comparitive to a degree and I reckon all up it was just over £10k and would have been £7k without the extra goodies.
The results however are fantastic and I'm enjoying every minute behind the wheel - just hide the invoice from the Wife or own up to 50% and still get a beating......
Cheers,
Dave.
DaveW is offline
Old 29th June 2009, 19:59   #79
dscam
Garage: E34 M5 3.8 - Daytona Violet
Classic. Love it!
dscam is offline
Old 30th June 2009, 00:09   #80
corneredge
Garage: 1994 M5 3.8L Avus Blue
Ah yes, my wife has figured out that whole 50% part of my past upgrades... so now I need to offset and carefully time the discussion to ensure the purchase goes through without too much reaction. Haha, adds to the fun.
Originally Posted by dscam View Post
Classic. Love it!
corneredge is offline
My almost disaster, Oil everywhere. Rate39d M E39 M5 and E52 Z8 Discussion 5 4th June 2008 20:48
DISASTER!!!...... BANKROBBER E34 M5 Discussion 99 4th December 2007 16:38
My M5 Disaster!! Mickmoll E60 M5 and E61 M5 Touring Discussion 4 20th August 2005 02:22
M5 Disaster Streak MJ E39 M5 and E52 Z8 Discussion 19 24th July 2003 23:37
Page generated in 0.15318 seconds with 12 queries
