Old 3rd May 2009, 00:11   #1
Blitzkrieg Bob
Blitzkrieg Bob's Avatar
Garage: 91 SterlingSilber-Metallic M5
Torque setting for T stat cover?
Almost done with my repair and the BMW TIS doesn' give a torque setting for he 5 T stat cover bolts for the S38.
Anybody know the Nm or Ftlbs?
Thanks in advance.
1990 525 Alpine Weiss, Miller MAF conversion, Eibach springs, and Dinan cigarette lighter.
1991 M5 Sterling Silber with TMS chip, SLS delete and Stebro exhaust
1994 525 Touring Calypsorot with 3mm spring pads
Blitzkrieg Bob is offline
Old 3rd May 2009, 01:18   #2
Blitzkrieg Bob
Found it!
8-10 Nm
Old 3rd May 2009, 14:39   #3
dscam
Garage: E34 M5 3.8 - Daytona Violet
Bob,
Hoping to refurb my t-stars in the near future and bought all new bolts for the job. The heads look unusual - what is the correct wrench/driver and size? Looks like a 'hex' or 'torx' but I'm not sure....
Hope you can help,
Duncan
dscam is offline
Old 3rd May 2009, 17:16   #4
Konfused Pete
Konfused Pete's Avatar
Garage: Black '90 e34 M5
M6 Star also known as Spline
Konfused Pete is offline
Old 3rd May 2009, 19:17   #5
dscam
Thanks Pete - greatly appreciated!
dscam is offline
Old 3rd May 2009, 22:03   #6
Blitzkrieg Bob
Originally Posted by dscam View Post
Bob,
Hope you can help,
Duncan
Sorry,
I was posting about the thermostat cover, I have the S38b36, and it has just plain old 10mm hex bolts.
Make sure you get the right tools, because the T Star cover bolts seemed to be a little sticky coming out and I had to drill out most of them and replace the with new stainless steel bolts.
When I replaced them I put some anti seize compound on them to help prevent frozen bolts (ferrous bolts into alloy parts) if I ever have to do it again.
Old 3rd May 2009, 22:22   #7
dscam
Bob,
My apologies for the blonde-moment! Completely missed the fact your post says 't-stat' and not 't-star'.......doh! Your advice all noted though and I'll ensure to do this as I suspect getting the old bolts out will be a pain.
Pete - thanks for your reply despite me making myself look stupid!
Cheers guys.
dscam is offline
Old 4th May 2009, 05:21   #8
Konfused Pete
If it makes you feel better, i read it as T-star also. haha whoops :P
E60 M5 6 speed vs E39 M5 performance stat J Irwan E60 M5 and E61 M5 Touring Discussion 8 4th January 2009 01:29
Valve cover bolt torque topper E39 M5 and E52 Z8 Discussion 8 27th July 2008 00:07
Torque setting for crankshaft studs? Úbermensch E39 M5 and E52 Z8 Discussion 2 26th November 2006 05:25
torque setting beacham E39 M5 and E52 Z8 Discussion 0 7th June 2006 20:49
Torque Setting Still 88 Ft/Lb For Stock Lug Bolts On An '02? Anita E39 M5 and E52 Z8 Discussion 11 14th May 2003 15:40
Page generated in 0.12231 seconds with 11 queries
