Old 25th February 2009, 18:23   #1
kiudog
kiudog's Avatar
Garage: M5 cosmic black
Anybody knows why?
hi there guys! just want to share this with you:
when i park my car overnight the rear suspension lowers itself....like this:
and when i turn on the beast she goes into normal again...
anybody can please explain why this happens? it this happening to somebody else?
how to fix this?
thanks !!!!!
KiuDog - mmm crazy
1995 E34///M5
2008 VOLVO C30 2.0
1994 XL 1200
1999 1340 FAT BOY
2005 HERITAGE SOFTAIL
2005 DEUCE
2006 ELECTRA GLIDE
I ride´em like I stole´em!
kiudog is offline
Old 25th February 2009, 18:45   #2
Crash & Burn
Crash & Burn's Avatar
Garage: E34 M5-Touring, Fjord Grau
Send a message via Skype™ to Crash & Burn
SLS problem
Welcome to the board. Please do a search on either sls, rearsuspension, pentosin, rear shocks, self levelling system, sls delete, PAS (Power assistance steering) or a combination of these.
This is probably one of the most discussed subjects on the board! No use in exaplaining here!
That it'll cost you money is a sure thing. How much remains the question based on detailed diagnose of the problem. (2 rear shocks > 2000 euro's, tubing, dividers etc...)
First thing to check is: Level of Pentosin (green stuff, maybe brown due tyo age and water) in the black canistor. Location: left front under the hood with a rather bif knurled knob on it. Undo the knob, check level. Level should be visible just above bottom of mesh. Fill her up if required.
The check read shocks. Remove rear wheel and check for seepage.
Damn... what am I doing..........do the search first
Anyway, welcome to the board. At least you got the sls which is offcourse original to the e34 M5
W
1995 Fjord Grau 3.8 sixspeed Touring
Crash & Burn is offline
Old 25th February 2009, 18:58   #3
kiudog
kiudog's Avatar
W
thanks crash & burn!
well, i did a research here before posting this, but unfortunatelly all my moves didn´t went to solving the problem:
I changed the two front struts for brand new ones...still don´t need to change the rears since they´re not leaking. changed the pentosin oil, it´s brand new and the level is just above the mesh, sometimes the level changes. had the suspension bleeded...thougth it was air in the sistem but it´s not...
the rear is really stiff, the front is alright though....
will continue my search....maybe one day get it solved....guessing when i change for new struts! heheh
also noticed that my steering is sometimes hard and sometimes soft...
anyway, thanks man!
KiuDog - mmm crazy
1995 E34///M5
2008 VOLVO C30 2.0
1994 XL 1200
1999 1340 FAT BOY
2005 DEUCE
2006 ELECTRA GLIDE
kiudog is offline
Old 25th February 2009, 19:03   #4
AlexA
AlexA's Avatar
Garage: 92 E34 M5 Touring Diamond Black
Stiff rear suspension sounds like the accumulators may be shot. That may explain the sagging over night as well. They are not too expensive, and relatively easy to replace. If you drive a lot with worn accumulators, the rear shocks will start leaking very quickly.
AlexA is offline
The Following User Says Thank You to AlexA For This Useful Post:
pspassos (26th February 2009)
Old 25th February 2009, 20:03   #5
Crash & Burn
YUP,
To Kiudog: Fronts are sealed shocks. They are not "connected" to the rears. Like Alexa says: Accumulators probably shot. They are about 200 euro's a piece and you'll need some tubing as well.
W
Old 25th February 2009, 22:59   #6
Steve Mac
Steve Mac's Avatar
Garage: 2001 M5 Le mans
Agree with crash and burn, the pentosin prob needs replacing as is probably original and at 13years that needs replacing
Cheaper than replacing accumulators in the short term, not def your prob but would be my first option
Steve Mac
_________________
If knowledge is power,,,how brainy are my Baby`s
2001 Le Mans beast ///M5
1995 Fjord grey M5 she's a lady
2002 Black Beauty 320i Sport!!
decisions decisions
Steve Mac is offline
Old 26th February 2009, 03:15   #7
kiudog
kiudog's Avatar
thanks for the reply!! Is there a Fault code for this accumulator error? I already changed the pentosin and bled the system.
in other words, how do I check if the accumulators are shot?
thank you!
KiuDog - mmm crazy
1995 E34///M5
2008 VOLVO C30 2.0
1994 XL 1200
1999 1340 FAT BOY
2005 DEUCE
2006 ELECTRA GLIDE
kiudog is offline
Old 26th February 2009, 08:33   #8
AlexA
AlexA's Avatar
Is the rear suspension really hard and bouncy? If so, I would say they are shot.
There are 2 of them, so if one is gone only, the symptoms will be less severe.
AlexA is offline
Old 26th February 2009, 14:46   #9
Crash & Burn
And they are placed above the rear axle against the bottom of the car. Leftone has is more difficult to reach due to the exhaust.
W
Old 26th February 2009, 16:08   #10
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Send a message via ICQ to pspassos Send a message via MSN to pspassos Send a message via Skype™ to pspassos
I think that was exactly what happened to me
kiudog, Brazilian suspension group buy?
lets go with the almight coilovers....
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline
Page generated in 0.19838 seconds with 10 queries
