Old 21st February 2009, 15:56   #1
Evoman
Garage: Lancia Delta Integrale Evo 1
Source of missfire?
Folks,
Been replacing coil packs and stems one by one hoping that would cure the missfire on my M5T to no avail so far.
However, I found a loose connection that literally came off in my hand - what is this for and could it be the source of the missfire I wonder???
Obviously I will reconnect it though the wire is tight with minimal available for resoldering the connection pins.
Cheers
Rich
Evoman is offline
Old 21st February 2009, 20:39   #2
davidoli
It looks to be one of the electric vacuum control valves .
See : http://www.realoem.com/bmw/showparts...68&hg=11&fg=45
Does your resonance flap actuate when you blip the throttle Richard ?
D
91 Sebring 3.6
E28 UK RHD M5
Last edited by davidoli; 21st February 2009 at 20:53. Reason: found diagram showing part .
davidoli is offline
Old 21st February 2009, 23:16   #3
Evoman
Hi David, does the resonance flap actuate when I blip the throttle? Well it did before I went messing! A^se
Evoman is offline
Old 22nd February 2009, 14:13   #4
farrell
farrell's Avatar
Sales Feedback: (4)
Discharge solenoid valve pictured & the wring to, faulty or otherwise can't cause mis-fires.
Where is the misfire within the rpm range ?
Can you drive through the mis-fire ?
Is it part or wide open throttle induced ?
Wether @ cold start or operating with coolant temp @ > 79 Deg C
will determine a diagnosis path.
Cheers
Farrell
www.darjac-racing.co.uk
farrell is offline
Old 22nd February 2009, 15:11   #5
Evoman
Hi Farrell
Thanks for the tips. The mis-fire is on part throttle low down the rev range, I would say around 2000-4000rpm and only when warm.
I would say the mis-fire can't be driven through unless you floor it and then it clears, so wide open throttle seems ok. Definitely no mis-fire higher up the rev range, or if there is, it clears much more easily.
So far I have removed and checked all plugs, re-gapped them to 0.6. One stem to one of the coil packs I replaced because the bottom 1cm was melted (?!) where it connects to the spark plug.
I was hoping once that and the coil on that cylinder were replaced that would be it, but oh no. So, 2 coilpacks and one stem replaced so far and a new throttle cable (previous one was fraying). MAF cleaned, new air filter, throttle bodies cleaned and balanced, valve clearances checked.
If you have some pointers where to go from here I would, it goes without saying really appreciate it!
Cheers
Rich
Evoman is offline
Old 22nd February 2009, 15:51   #6
farrell
farrell's Avatar
Sales Feedback: (4)
Ok Rich
If you want, I will send you 4 used but known to function coil packs to eliminate that side.
I will send you a used but known functional B38 MAF.
That will eliminate MAF.
Cost is postage only so probably less than £10
Send me your details via PM
If this does not work, we can explore other paths one step at a time.
You may not immediately hear from me due to big projects looming.
Phone me if I do not get back via pm.
Cheers
Farrell
farrell is offline
Old 22nd February 2009, 16:11   #7
davidoli
Wow ...... One big happy E34 M5 loving family !
You can't get better than that Rich ......Good luck with the misfire and please keep us updated .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 22nd February 2009, 18:24   #8
nebpor
Garage: Avus Blue E34 3.8 M5
Agreed - excellent offer from Faz!
Rich - if you want to take car down to our garage in Greenock to help diagnose Cha would be happy to have a look!
nebpor is offline
Old 22nd February 2009, 21:14   #9
davidoli
Great stuff Stephen .......
Best of luck getting this sorted Richard .
Efficient combustion is required for an efficient combustion engine .....it's not Rocket Science !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 23rd February 2009, 01:18   #10
Evoman
Originally Posted by farrell View Post
Ok Rich
Cheers
Farrell
I know this board is full of gents and ladies of a more discerning and amicable nature than most, that is however a very generous offer that I will happily accept! PM on the way.
Cheers
Rich
Evoman is offline
Page generated in 0.15212 seconds with 11 queries
