Old 13th February 2009, 00:20   #1
davidoli
Calypso Candice Clutch Replacement
Candice was absolutely flying on Sunday at Snetterton , until a dreaded case of clutch slip suddenly kicked in after a few hot laps .
The fact that she would pull strongly again , without clutch slip , after being allowed to cool down before beginning to slip again once hot suggested a combination of clutch wear and possible rear crank seal leakage .
Either way , the gearbox and the clutch had to come off in order to inspect the parts .
The Flywheel and Rear Crank Seal :
Old Clutch and New Replacement ( Don't new parts look sooo sexy :
The gearbox had a relatively large amount of engine oil inside upon removal , confirming that the rear main seal was leaking .
Original Rear Crank Seal :
New Rear Crank Seal Fitted :
New Clutch Fitted :
The roadtest indicated that the clutch is now performing as required , so roll on our next trackday .......possibly Bedford Autodrome next week !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
The Following 2 Users Say Thank You to davidoli For This Useful Post:
Jon Baker (16th February 2009), Steve Mac (13th February 2009)
Old 13th February 2009, 20:36   #2
stevie sam
stevie sam's Avatar
Garage: E39 M5 Carbon Black with Black/blue leather.
Nice one D......
Speed is determined by the right foot....progress is determined by the brain..................
stevie sam is offline
The Following User Says Thank You to stevie sam For This Useful Post:
davidoli (13th February 2009)
Old 13th February 2009, 20:36   #3
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Send a message via ICQ to pspassos Send a message via MSN to pspassos Send a message via Skype™ to pspassos
dont you have a dual mass fywheel to sell me?
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline
Old 13th February 2009, 22:34   #4
davidoli
Unfortunately not !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 13th February 2009, 23:57   #5
roortube
Garage: 1991 Dinan M5, black; 1993 s4/rs2; 1969 Lotus Elan +2S130
D
how did you address the flywheel? As I understand, they can't be machined on a lathe, so...emory paper to remove glazing, or just re-use as is? I'll be doing this same job due to release bearing grind in a few months, and I figure that the flywheel should be in pretty decent shape since the clutch isn't slipping. Any suggestions re. flywheel?
thx,
Rob
roortube is offline
Old 14th February 2009, 00:18   #6
davidoli
Hi Rob ,
The flywheel was cleaned up with emery paper and brake disc cleaner before being refitted .
A small quantity of high temp grease should be put on the gearbox spline before refitting also .
Good luck with your renewal .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 16th February 2009, 19:37   #7
Jon Baker
Jon Baker's Avatar
Garage: E34 M5 3.8 - Daytona Violet
D,
Thanks for your time and efforts over the last few weeks, the difference in Calypso since all the new 'bits' have been fitted is immense.
Can't wait for Friday, first chance to compare Calypso's performance with my memories of FUG's.
Bedford will be very interesting - Hope you are able to join us....
Jon Baker is offline
Old 17th February 2009, 09:01   #8
stevie sam
stevie sam's Avatar
Originally Posted by Jon Baker View Post
D,
Hi JB, have a good day Friday.......memory's of FUG's - have you sold her on Jon.....?
Old 17th February 2009, 15:50   #9
Jon Baker
Jon Baker's Avatar
No chance - FUG will never be sold. She is just resting this year to allow funds to be diverted into the calypso track car.
FUG will more than likely be resurrected for a few outings next year.
Hows the E39?
Old 18th February 2009, 09:05   #10
stevie sam
stevie sam's Avatar
Hows the E39?
Nice one Jon.........you mean to say you cant run two e34 M5's in a recession ....shame on you Jon......ha ha.................My E39 is doin ok thanks, just passed MOT and got the anti roll bar links done too....
Page generated in 0.16665 seconds with 10 queries
