Old 11th February 2009, 18:59   #1
cspargo
cspargo's Avatar
Garage: 1991 E34 m5 Schwartz
Oversize valves in B36 head?
So I'm having my cylinder head rebuild, replacing guides, a few exhaust valve seats, etc. Got me thinking about the relative value of replacing the stock valves with oversize.
Any input one way or the other?
Any cautions on replacing the guides? Don't know if they're machined out or pressed... ( Good thing I'm not doing the work..... )
cspargo is offline
Old 12th February 2009, 05:08   #2
corneredge
Garage: 1994 M5 3.8L Avus Blue
I don't see a reason why you couldn't upgrade to the S38B38 valves, just be sure to check valve springs and other variables as well.
corneredge is offline
Old 14th February 2009, 00:02   #3
roortube
Garage: 1991 Dinan M5, black; 1993 s4/rs2; 1969 Lotus Elan +2S130
you should call the guys at VAC motor sports...they're in the USA and have consderable experience w/ S38 performance up grades. They'll be able to walk you through the pro's and con's of cylinder head modification as it relates to this specific engine.
roortube is offline
Old 15th February 2009, 10:11   #4
WillM5
WillM5's Avatar
Garage: E34 M5 Diamantenschwarz
Korman Motorsports uses bigger valves in their setups as well. Metric Mechanic knows a great deal about the S38 Valve train as well. I have delt with them personally and the owner Jim Rowe has a vast knowledge of the motor. I almost went with the upgraded valves on my engine but didnt as i was on a budget. I did use there valve guides thou, and they are by far the best i have come by. 1-573-765-1269 and ask for Jim, great guy and will tell you anything you want to know about your valvetrain. Tell him Will sent you.
Engine : S38B36 - MM 296° Rally Intake Cam, E28 Exhaust Cam (248°), Race Port (31mm) , High Lift Valve Springs, High Performance Rings, Refreshed Bottom End, Port Matched Throttle Bodies, BMC CDA Intake
Exhaust : Wrapped Headers, Straight Exhaust, Supersprint Resonator, Eisenmann Race Exhaust
Suspension : H&R Sport Springs, Koni Yellows, M5T Rear Sway Bar, Racing King Rear Subframe Inserts
Exhaust Clip http://www.youtube.com/watch?v=I3CSE39PTCA
WillM5 is offline
Page generated in 0.09038 seconds with 10 queries
