Originally Posted by ///Manuel
Also, I don't believe the MAF plays a big role above 4k rpms but I may be wrong...
Failed hot wire mass metering units when worn will give incorrect voltage input
to DME.
Typically, they will run the engine rich @ stoich leading to poor part throttle fuelling & pick up.
At WOT , the result can be dangerously the opposite with lean AFR, leading
to potential engine damage.
Cheers
