Old 11th February 2009, 00:46   #1
///M5 Touring
Garage: bmw e34 m5 touring schwars II
Starting problem
my e34 m5 has a problem,
when i turn the key it wouldnt start. nothing happens.
i checked det starter and its as good as new.
is it the key ignition that is the problem?
i have heard that its a "tap" in there that breaks and it wouldnt start.
i dont have ews on my car.
///M5 Touring is offline
Old 11th February 2009, 01:23   #2
davidoli
Do you get any dashboard lights on when you turn the key ?
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 11th February 2009, 10:33   #3
///M5 Touring
Yes i do
Old 11th February 2009, 11:31   #4
IvanDias
IvanDias's Avatar
Hi,
If the dash lights come on as normal, but when the key is turned they flicker and you hear a light "fluttering" noise, it's likely to be a flat or dead battery. Stick a multimeter on the battery and read off the charge level.
Do you get the battery light come on with the dash lights on initial key turn or does it stay off? If it's staying off, it's possibly a failed volatage regulator on the alternator, which has led to the flat battery.
Hope you get it fixed!
Regards
Ivan
IvanDias is offline
Old 11th February 2009, 13:11   #5
///M5 Touring
It charges 13,9 volt. The battery is 2 months old
Old 11th February 2009, 19:24   #6
///Manuel
Garage: various cars
Can you jump the car?
Since the battery was recently changed maybe the cables weren't tightened correctly?
Any corrosion from the previous battery?
///M Driver Touring Pics
LE Picture
///Manuel is offline
Old 11th February 2009, 19:55   #7
davidoli
Are you saying that when you turn the key fully , the car does not even crank i.e. the starter motor doesn't engage ?
If so , there is a possibility that your key / ignition assembly / barrel is at fault , which I can elaborate on if this is your issue .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 11th February 2009, 20:42   #8
farrell
farrell's Avatar
Sales Feedback: (4)
What method has been used used to test the operation of the Starter motor / solenoid ?
Cheers
www.darjac-racing.co.uk
farrell is offline
Old 12th February 2009, 00:08   #9
///M5 Touring
yes i can jump start the car. if you mean i can push it forwards and engage the clutch in 2nd gear
Old 12th February 2009, 00:10   #10
///M5 Touring
D
yes that is correct. you know how to fix?
Page generated in 0.13619 seconds with 10 queries
