Old 13th February 2009, 00:20   #21
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....waking up
Dave,
I don't think that piece will need replacing.
More likely part number 3 and or 5 in your earler realoem link.
The barrel has a 'tongue' which fits into a 'groove' in the other piece. From memory one of them is plastic and could wear.
The ignition barrel is fairly easy to remove with a paperclip or similar inserted into the small hole wile turning. I think the procedure is in the bentley manual.
Look on the bright side, if I don't drive it for a year (2 years) the engine rebuild will pay for itself.(I'll make a profit!!).
GoneAgain is offline
Old 13th February 2009, 00:31   #22
davidoli
Hallo Tel ,
I'm not so sure after suffering this problem at the Nurburgring last July .
The centre pin that runs from the ignition barrel to part number 3 doesn't always engage fully and therefore the engine doesn't crank.
We had to disconnect part No 3 from the rest of the ignition barrel and use a screwdriver inside that white plastic aperture in part 3 to start the engine , whilst at the same time leaving the key turned in the ignition barrel to release the steering lock .
Upon our return , the part that I have photographed was replaced so that the ignition worked correctly again ......the ignition barrel and key remained ......
p.s. It's not always so easy to release that ignition barrel ......Thank God we don't have a swearbox in the workshop !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 16th February 2009, 00:38   #23
///M5 Touring
Garage: E34 M5 Touring daytona violett nr. 041
ive looked at the wiring and "shaked" it a little and now the car starts. so i think i just need to change the wiring
///M5 Touring is offline
The Following User Says Thank You to ///M5 Touring For This Useful Post:
davidoli (16th February 2009)
Page generated in 0.08824 seconds with 10 queries
