Old 6th February 2009, 23:07   #1
davidoli
Can 3.91 LSD Fit E34 540i ?
Hi guys , I am reasonably sure that a 3.91 5 speed M5 LSD will fit a 540i , although as I understand it , the 540I came with a 2.93 diff as standard .
What would the effect on driving characteristics of fitting the 3.91 to a 540i be .......does the 540i rev high enough to carry a 3.91 LSD ?
TIA .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 6th February 2009, 23:42   #2
///Manuel
Garage: various cars
Yes V8's and big 6's shared the same large case diffs.
I like this little gear calculator to figure out speeds and rpms.
3.91 will be too high for the 540i tranny though.
///M Driver Touring Pics
LE Picture
///Manuel is offline
The Following User Says Thank You to ///Manuel For This Useful Post:
davidoli (7th February 2009)
Old 6th February 2009, 23:44   #3
gwm635
gwm635's Avatar
Garage: 1990 E34 M5 3.6 & 1985 M635CSI Arctic Blue
Hi David,
I stand to be corrected here, but I think it is very dependant on the gearbox. The 6 Speed M5's run a 3.23 diff, which makes the first 5 speeds the same gearing as a 5 speed, 3.91 diff M5 (which always feels like it needs another gear on the motorway).
I would imagine a 6 speed 3.91 would scream!!
I've attached a spreadsheet I did to calculate gearing for a project I've got in mind. Hope it makes sense...
Garry
1985 E24 M635CSi Arctic Blue/Pacific Blue Leather
1995 E34 525iT Oxford Green/Silver Leather
1990 E34 M5 3.6 Sterling Silver/Silver Leather (she broke my heart and then she left me...)
Australian M6/M635 Group http://autos.groups.yahoo.com/group/...guid=204255579
gwm635 is offline
Old 6th February 2009, 23:46   #4
gwm635
gwm635's Avatar
Try Again...Gearing workings office 03.xls
Garry
gwm635 is offline
The Following User Says Thank You to gwm635 For This Useful Post:
Old 7th February 2009, 04:07   #5
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Send a message via ICQ to pspassos Send a message via MSN to pspassos Send a message via Skype™ to pspassos
I think that wuld be astonishing at the track.....
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline
Old 8th February 2009, 00:05   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
TIA .
D
I believe the 540 rev's to about 5800-6k rpm, so fitting a 3.91 will certainly limit in-gear speeds.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
The Following User Says Thank You to mottati For This Useful Post:
davidoli (8th February 2009)
Old 8th February 2009, 12:50   #7
hoyleyboyley
Garage: hunting for an M5
davidoli,
as stated as long as its a big case diff it should fit AFAIK.
HOWEVER, i researched into it a little bit and with the M60 V8 i think that anything over 3.46 will be too highly geared to be of any use when driving! you'll spend all of your time changing gear...
in the end i opted for a 3.15 LSd diff from an E32 750i - straight swap and the gearing is now set for acceleration more than the std lazy 2.91 diff.
i'm in SE london/kent, so if you're in the area you're more than welcome to come and have a go and see what you think...
its just about right IMO, quick enough to stay with my mates E36 M3 evo (probably dodgy ground on here , but i think it would *just* pip a 3.6 M5 in a drag) while not being TOO high up the gears when on a long run.
now everything is a bit more up the rev range, but its still driveable.
cheers,
hoyleyboyley is offline
Old 8th February 2009, 13:18   #8
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....waking up
Try this
E34 M5 Differential Hnterachse mit Sperre S 3,23 6-Gang bei eBay.de: Lenkung Achsaufhängung (endet 10.02.09 20:45:00 MEZ)
Look on the bright side, if I don't drive it for a year (2 years) the engine rebuild will pay for itself.(I'll make a profit!!).
GoneAgain is offline
Old 8th February 2009, 19:42   #9
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
ok, for road use I agree with you guys.... but for the track, that 3,91 would be awesome
pspassos is offline
Old 8th February 2009, 19:54   #10
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
6 speed M5 + 3.91 LSD is stunning on track. Acceptable on road but you do spend alot of time changes gears!
On a 540i it would be a little too short IMHO.
Avus Blue 6 speed 3.8L E34 ///M5 Sedan
Evolve ECU Remap / Chip | Evolve Carbon Intake | Powerflex Black | Whiteline | Eibach Springs
2001 E39 530iA Sport
Cyrus is offline
Page generated in 0.13406 seconds with 11 queries
