Couldn't find my specific problem in a search so I would like your opinions.
I was driving home last weekend on the freeway (at night) and accelerated briskly to get around some slower cars, suddenly alarms went off. The instrument cluster indicated the Batt light was on, the ABS light was on, then I noticed the coolant temp started to climb rapidly. I shut off the engine at 70 MPH and coasted to the next exit where I sat for about 15 minutes trying to decide what happened. I fired up the car and drove about 1/4 mile to a gas station as the temp started rising again. I shut it off and opened the hood, no problem was visible so I looked under the car. Coolant was pouring out around where the transmission is.
I had the car towed home, and just got a chance to work on it this weekend. The belt that drives the water pump and alternator had disintegrated. The pieces I found were hard brittle chunks of belt, obviously way past time to be replaced. I should've guessed that because the Batt light came on. So I got a new belt and put it on today. I put some coolant back in and fired up the engine, monitoring the coolant level in the expansion tank and looking under the car for leaks. No leaks initially, but as the temp came up to the normal range water started dripping out under the car about where the transmission is. So I jacked the front of the car up and put it on blocks so I could get underneath and find out what was leaking.
I found water leaking out of two holes about 3/4" diameter above and on either side of the transmission. The holes come from within the chassis and empty out above the transmission on either side. My guess is that the heater core (or plumbing to or from it) is leaking, and that there is a channel or ductwork that allows coolant to drain out of the car instead of inside the passenger compartment.
Does anyone have experience with a leaking heater core, and is that likely what my problem is?
Tks for your assistance...
Mark -
