Old 28th December 2008, 17:21   #1
BANKROBBER
BANKROBBER's Avatar
Garage: m5 3.8 1993 lagoon green metalic
Send a message via MSN to BANKROBBER Send a message via Skype™ to BANKROBBER
HID kit....
....just wanted to see if there were any guides on here to fitting them in my e34?
looking under the bonnet,there aint alot of room!!
ROB
BANKROBBER is offline
Old 29th December 2008, 22:33   #2
AndyHudds
Garage: 1993 E34 M5, (think calypso red)
Hiya Rob
They are a piece of cake to fit, the biggest problem is finding somewhere to mount the ballast boxes, i mounted one of mine under the alarm siren on the left hand side and starpped the right hand ballast box to the cross member behind the right light cluster.
mounting the bulbs was just punching a 20mm hole in the cap of the headlight, and squashing the rubber gromit in.
I'd get you pictures but my cars been locked away in its garage for the past 2 months
Andy
AndyHudds is offline
Old 29th December 2008, 22:49   #3
BANKROBBER
BANKROBBER's Avatar
thanks for reply....
....i have found some more info also.
i had a look today again and i can see where you mean,np.
my only other prob is that....i have 'extra' wires that i dont think i need to use.....i am going just for the direct plug-in setup and replacing the 7.5amp fuses to 10amp.
also...i read that the ballast bodies should not ground.however,this kit has an earthed mounting bracket.
i may just connect it all before to test it out etc
hoping to fit these over next few days,think should be ok.
thanks again
ROB
Old 30th December 2008, 16:05   #4
BANKROBBER
BANKROBBER's Avatar
fitted...
....and all seems ok.
changed out the 7.5amp for 10amp fuses and the fitting went well.
its a damn tight fit just to get the bulbs in on my 3.8 but was real carefull and managed to get them in!
ballast box on rh side is fitted inbetween the light cluster housings....so its not visible with the cover on.lh side will be the same but for today it is just cable tied to the oil filter housing.
i take it that the cables must hang down on the resistor box assembly?
anyhow....i will be flying down the darkest road i can find!
they are so much brighter than normal even in the daylight,so i am now very happy.wish i had got off my a**e earlier and done them.
on a sad note.....where the expansion tank fits to the inner wing....its rotted through!! further investigation required
ROB
Old 30th December 2008, 19:08   #5
BANKROBBER
BANKROBBER's Avatar
just been out.....
....testing lights.
awesome light....fantastic.need to adjust beam lower,but amazing
now,getting 'dip beam' error....need to rectify that.....anyone??
ROB
Old 4th January 2009, 07:41   #6
SpecRaceM5
SpecRaceM5's Avatar
Garage: White '91 m5
Send a message via AIM to SpecRaceM5
.DM - HID, DEPO Lighting, BMW and Mazda Performance Accessories
858.565.1742
Talk to Leif or Jim if you can, but if they are not available, Paul or Marcus should be able to help you. They have a harness that should fix this problem. Hope it helps.
Cheers,
Brian
BMW STEP owns me.
SpecRaceM5 is offline
Old 4th January 2009, 12:49   #7
gwm635
gwm635's Avatar
Garage: 1990 E34 M5 3.6 & 1985 M635CSI Arctic Blue
Originally Posted by BANKROBBER View Post
....testing lights.
ROB
The Xenon globes don't draw the same amount of current as a standard globe so the CCM thinks a globe has blown.
It is a problem in any vehicle with a warning system where HID or LED replacement globes have been fitted. Go to your local Auto Parts store, explain your issue and they will sell you a resistor to put in the line for not much money
Garry
1985 E24 M635CSi Arctic Blue/Pacific Blue Leather
1995 E34 525iT Oxford Green/Silver Leather
1990 E34 M5 3.6 Sterling Silver/Silver Leather (she broke my heart and then she left me...)
Australian M6/M635 Group http://autos.groups.yahoo.com/group/...guid=204255579
gwm635 is offline
Old 5th January 2009, 19:47   #8
BenS
Garage: 1994 E34 M5 Avus Blue
You need a resistor between the two leads that supply the dipped beam. This fools the computer into thinking that you still have a light bulb in place. I got mine for a few quid from CA automotive who are sponsors of this Board and supplied my kit. Good luck.
Ben
BenS is offline
Old 6th January 2009, 10:19   #9
farrell
farrell's Avatar
Sales Feedback: (4)
Interesting that you gents are experiencing OBC check light faults.
Can you confirm which kit this is & wether the ballast control is digital or analogue ?
This did happen with some 1st gen aftermarket analogue ballasts a few yrs ago, but only the cheaper
ballasts seemed to do this.
I've fitted some 70 kits to E34's & not had to resort to in-line resistors in 4 yrs of fitting them.
Thats not to say that you don't occasionally get a instrument fault on the OBC but this can be
down to a poor earth in the wiring.
In the above case this appears to be caused by the initial switching of the ballasts from cold
when the voltage draw is at peak to support the 23Kv required to light off the light capsule.
After 8 secs, the voltage runs @ 8Kv.
That said, I have one car that awaits a check to resolve wether part or wiring is at issue & its symptoms are very unusual.
However, these installs tend to be reliable & in all the kits I have fitted, only two including that mentioned have given issue.
www.darjac-racing.co.uk
farrell is offline
Old 11th January 2009, 22:20   #10
BenS
Darren: Not sure if my kit is digital or analogue. Got it a couple of years ago from Ca automotive. Made by Apex Cone. Not that impressed by it. Gives fantastic light (will never be satisfied by anything but Xenons in future!) but looks like a cheapo ebay special from far East. However it was not that cheap! It blows a fuse from time to time as well. I should have got one of your sets!
Ben
BenS is offline
Page generated in 0.14678 seconds with 11 queries
