Hi,
It's been a while since last I visited the board. The E34 M5 has been sitting in the garage about one year now due to other priorities.
I have found that the car has some severe rust problems. The front left jacking point "disapeared" when I tried to use tha jack. It has gone some 5 cm ( 2 inches) upwards. In fact, all jacking points are very rusty. This is probably caused by the roof hatch drainage that ends inside the sills(so I'm told). I suspect that there is quite som rust in the floor as well.
I don't have the skill to rebuild it my self so it will probaly be quite costly to have it fixed. I do not want a quick fix welding job, I want a proper job and I am trying to figure out what parts will be needed to fix this. I have been looking at spare parts like 41001946315 (COLUMN B WITH LEFT ROCKER PANEL) and 41001946313 (LEFT EXTERIOR COLUMN A) but I don't know if these parts are sufficient to repair the hard structure of the jacking points. Does anybody know?
I also have some rust in the doors as well but that is a minor problem.
About two years ago I bought new brake discs, new piping, new seals etc but I haven't had the time to put it on the car. That was just after I completely restored the interior. The question now is
hould I scrap the car or fix it?" It is probably a very silly question to put to this board
but I would appreciate some answers based on experience of how difficult and how expensive it is to fix major rust problems.
Cheers
