Hi
Thats different.
The location for the Turbochargers.
They seem very close to the bulk oil of the engine & transmission.
(Might be the angle of the pics)
Are you going to shield these parts from exothermic heat soak ?
The vehicle has an aux oil cooler which does its job on the std engine.
Have you got any generic or projected engine bulk oil temps ?
I notice that you are running integrated poppet valve wastegates in exhaust housings.
I have found that heat stressed areas where heat can be trapped or exhaust gas temps get
high for extended periods, I have had these poppet valve waste gates seize part open.
The cure was inconel poppet valves or remote waste gates.
The remote waste gates is best solution imho but space is tight here.
How much MAP will you run at ?
Good luck with the old girl
Cheers
