Old 4th September 2008, 00:32   #1
Blodstrupmoen
Blodstrupmoen's Avatar
Garage: 1992 E34 M5toruing , cosmos Black
Exhaust options for M5T
What are my options here? I allready has a Eisenmann back box , but the rest of the exhaust needs to be updatet. Especially the muffler between the cats and the backbox will not survive the winter. The cats are probably fine but the connectors on both sides has been cracked and welded numerous times.
Would a couple of race cats from Summit do the trick ? As I think my car is loud enough I don`t want to remove the second muffler , but what can I use instead ?
The plan was to buy all muffler, cats and piping and get a friend of mine to weld it togheter..
Blodstrupmoen is offline
Old 4th September 2008, 18:49   #2
Blodstrupmoen
So no one has replaced exhaust with other than complete stock system ? ( yea I know about the guy using race cats and eisenmann , but that is too loud for me )
Old 4th September 2008, 22:06   #3
DrSakke
DrSakke's Avatar
Hi!
The exhaust is the same as for the sedan, I believe some have used SuperSprint midsection together with the Eisenmann back box.
Otherwise the solution you describe should not be bad either, provided that flow and dimensions are correct.
Sakke
DrSakke is offline
Old 4th September 2008, 22:14   #4
Blodstrupmoen
Ok check out the supersprint thing then.. We tried without the middle muffler and it was WAY to loud for everyday use ...
Race cats , supersprint and Eisenmann .. stock dimensions . I`m not to keen on SS so maybe it would be thermal coated mildsteel .. I check with my welder..
Exhaust/Cat options Sebring NL E34 M5 Discussion 7 18th August 2007 02:21
Exhaust options __Andy__ E39 M5 and E52 Z8 Discussion 3 2nd August 2005 20:16
Exhaust options ?? Redder than red E39 M5 and E52 Z8 Discussion 3 24th April 2002 00:04
Exhaust and chip options? Xipe E34 M5 Discussion 3 8th September 2001 22:57
exhaust and tip options ALIAS E39 M5 and E52 Z8 Discussion 4 10th February 2001 23:01
Page generated in 0.11993 seconds with 11 queries
