Old 21st August 2008, 06:13   #1
woods
Garage: 91 M5 - Diamantschwartz
Front Suspension - Proper Torque Values
Hi All -
I've searched the interweb high and low with no success and I don't own the Bentley manual for the e34 so if somebody could kindly let me know what the proper torque values are for:
- 19mm Strut to Steering Knuckle bolt
- 19mm Caliper Carrier bolt
- 12mm Strut Bearing nuts
- 22mm Bolt for the thrust arm
- Ball joint to steering knuckle torque for thrust arm
- Lug bolts - are they 74 Ft lbs?
...it would be much appreciated...
Thanks in advance -
woods is offline
Old 21st August 2008, 17:06   #2
E34_nut
E34_nut's Avatar
Garage: E34 540i LE 6sp. - Calypso Red / Black Leather
Hi Woods,
If you're going to do this sort of work, you should really get yourself a Bentley Manual. There are a number sites on the web, probably seriously infringing copyright, where most of the Bentley Manual is available for download.
Not sure what consititutes a "steering knuckle" in a McPherson Strut ?
If you're talking about the 3 bolts that secure the steering arm to the bottom of the strut housing - 110Nm Bentley pg 310-6 use Loctite 270. They do work loose if you don't !
Front Brake Caliper to Strut Assembly - 110Nm Bentley pg 340-6
(Caliper to Carrier is 35Nm.)
Strut Bearing Nuts (Strut Assembly to body [3 nuts]) - 22Nm Bentley pg 310-3 DO NOT REUSE OLD LOCK NUTS !
Thrust Arm to Connecting Crossmember - 127Nm Bentley pg 310-10
Thrust Arm Ball Joint to Steering Arm - 93Nm Bentley pg 310-10
Lug bolt (Wheel Bolts ?) - Road Wheel to Hub - 100Nm Bentley pg 310-10
That should keep you entertained for a while.
If in doubt, there is table in the front of the Bentley Manual that provides default torque settings for nuts and bolts in these cars, when values are not specifically stated.
Reg.
from THE Antipodes , the real Land of Aus.
"You're gunna die of something, it might as well be fun !"
'88 Ducati 851 Superbike Strada - the original tricolour
'83 Ducati Mike Hailwood Replica - "900" kick start
Imagine a luxo like an E38 "L" with the current 4.0L Diesel !
E34_nut is offline
Old 21st August 2008, 17:52   #3
woods
Originally Posted by E34_nut View Post
Hi Woods,
Reg.
Much appreciated...
For the number if times I've posted "buy a Bentley on BMW-related internet forums" - I will admit some slight embarrassment. I usually just grab torque values for similar sized bolts my E36 bentley but wanted to be 100% sure about these particular bolts for obvious reasons....
Cheers.
woods is offline
almost burned through front tires = suspension help ///PCH E39 M5 and E52 Z8 Discussion 10 7th February 2008 17:22
E60 M5 Suspension torque specs mxk116 E60 M5 and E61 M5 Touring Discussion 7 6th June 2007 20:37
BMW M6 Convertible Press Release 2: Chassis and suspension (in English and German) Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 23rd June 2006 00:05
OT New Z06 rebel1 E39 M5 and E52 Z8 Discussion 86 12th January 2005 01:43
'02 Aluminum Front Suspension Tomk E39 M5 and E52 Z8 Discussion 4 8th August 2001 22:53
Page generated in 0.11308 seconds with 11 queries
