Old 7th August 2008, 16:31   #1
WMWNWMN
WMWNWMN's Avatar
Garage: 1992 euro M5
95c oil temp... too high?
my 3.8L was down from mid april-the end of july. In that time i replaced all coolant hoses/t-stat and water pump, as well as new front and rear brakes.
anyways, i've driven the car 3 times, with one stint up to 240kph. the engine oil temp creaps past the 90c mark and sits about 95c. water temp stays dead center.
I never remember the oil temp going past 90c before.
also, i now only get hot air out of the HVAC. this will be great for the winter, but were still 4 months off from cold weather, and i'm dying here with the windows up and 180kph!
WMWNWMN is offline
Old 7th August 2008, 17:07   #2
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
My Bi-Turbo runs around 85, except in the summer when anything up to 100 is normal if you include traffic. 118 on the Ring and anywhere in between on the Autobahn (not UK Motorways) above 200kmh.
According to the handbook, the RS 10/60 in my car is good for 125 (or more) without problems so I don't think your 95 degrees is anything to worry about.
Cheers,
Dave.
DaveW is offline
Old 7th August 2008, 17:18   #3
E34_nut
E34_nut's Avatar
Garage: E34 540i LE 6sp. - Calypso Red / Black Leather
Check the "Half AC Half Hot Constantly" Thread
This thread might help
Half AC, half hot (constantly)
If the drivers side temperature control is set to "Max Heat", the car will turn all heaters on and ignore the sensors. If that switch that detects the drivers side dial set to max has failed in the on position, that could cause the problem. More likely is Allan Archer's diagnosis in the thread.
Reg.
from THE Antipodes , the real Land of Aus.
"You're gunna die of something, it might as well be fun !"
'88 Ducati 851 Superbike Strada - the original tricolour
'83 Ducati Mike Hailwood Replica - "900" kick start
Imagine a luxo like an E38 "L" with the current 4.0L Diesel !
E34_nut is offline
Old 7th August 2008, 17:25   #4
E34_nut
E34_nut's Avatar
What Viscosity Oil Are You Running ?
I'm no oil expert, but here's something to consider.
Does the oil viscosity you're using in the car match the viscosity recommended by BMW for the ambient temperature you're experiencing.
If the oil you're running is a higher viscosity (particularly the second number of the viscosity because that's the viscosity of the oil at temperature) than the recommended oil viscosity, the oil will take longer to flow through the engine and I'm guessing it will collect more heat.
Just something to think about.
Reg.
E34_nut is offline
Old 7th August 2008, 17:28   #5
///Manuel
Garage: various cars
Motor Oil
212F = 100C
302F = 150C
///M Driver Touring Pics
LE Picture
///Manuel is offline
Old 7th August 2008, 21:55   #6
bubba966
bubba966's Avatar
Garage: Cosmos '95 540i M-Sport
Reg.
That's a good point. If you're using thicker oil it won't circulate through the block as fast as thinner oil does. So it collects more heat running slower through the block.
I'm not going to be too surprised if you say you're running 10w60 in the car as that'd cause it to run warmer.
bubba966 is offline
Old 7th August 2008, 22:00   #7
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Reg.
i've had the same experience with my e39, that i used to track quite a bit. Going from tws (10w60) to a 5w40 oil lowered my on track oil temp by about 15F on a warm day. My e39 is a late 00 model year, so tws is not a requirement for it.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 7th August 2008, 22:48   #8
Lantz
Lantz's Avatar
Garage: BMW M5 E34 Granitsilber Metallic 3.8
I run 10-60 TWS and my oil temp is always around the 100 mark. Water is dead centre.
Not sure if this is something to worry about.
Lantz is offline
Old 8th August 2008, 00:18   #9
midnightsun2
Garage: e34 M5 Touring Daytona violet
Thermostat in Oilfilterhousing
Hello WMWNWMN
Although the value of my expertise in motor maintenance has dropped a little since my "hole in the pocket"
The Oil temp readings you mention makes me suspect a failed or stuck termostat in the oil filter housing.
This thermostat controls the bypass to the oilcooler and should operate between 90 and 110 degrees (Celcius)
If when the oil is @ 80-85 degrees you drop the hammer and accelerate to V-max the oil temp should gradually rise to 110 and then when the termostat opens...drop fast to the 85 -90 range and stay there.
Over time the thermostat can become sluggish and or seize in any given position. If its stuck in the open position it will take longer for the oil temp to reach 90 and will hardly ever get above this reading.
If stuck in closed or partially closed position the oil temp will gradually rise to 90 if the revs are below 4200 and continue to rise to 100 - 115 between 4200 - 5200 rpm it will continue to rise at rpm beyond this range but never above 120 125.
This is still within the operating range of any good oil (like TWS) although it should not be sustained for prolonged periods.
I had the same problem last year starting with increasing oiltemp readings in spring, but as these increments were very graduallly I did not notice it until the end of summer. Each time we worked on the car (which was not very frequent) I first checked and repositioned the ducting which was not aligned properly, no result, the next time I cleaned the cooler surface, no result. Then changed the sensors, again zilch.
Then Stevie told me about the thermostat (which is not mentioned on the OEM drawing) So I ordered a new oil filterhouse, oil cooler and the connecting hoses (the connectors of old hoses are prone to breaking when trying to disconnect them)
This cured the problem and resulted in the proper temp readings right up until the moment the #4 cillinder lost a big end bearing
(which was a non cause and effect incident)
with kind regards
Tamar
midnightsun2 is offline
The Following 2 Users Say Thank You to midnightsun2 For This Useful Post:
davidoli (8th August 2008), Lantz (8th August 2008)
Old 8th August 2008, 20:25   #10
Closing_Time
Garage: E34 M5 Touring 92 - Granitsilber Metallic
In my car the oil temperature in normal condition of use is 90c and the water temperature remains just before the half.
If i push on the highway or on roads of mountain the oil temperature climbs toward the 100c and at times also to 110c while that of
the water never overcomes in any case the half.
Closing_Time is offline
Engine oil lewisng E60 M5 and E61 M5 Touring Discussion 21 1st September 2007 20:11
Oil Temp too low? BBM5 E39 M5 and E52 Z8 Discussion 3 29th December 2006 01:21
DIY Dummies Guides to Oil Change using Fluid Extractor HDClown E39 M5 and E52 Z8 Discussion 0 18th September 2005 01:46
Q: Is oil temp change normail after service? M5_Surge E39 M5 and E52 Z8 Discussion 12 8th February 2001 12:52
Page generated in 0.16921 seconds with 11 queries
