Originally Posted by davidoli
I'd be interested to hear where SS could lose an additional 100kg for under £100 , and please don't say by pushing Steve out of the door !
D
As said before, the sunroof is a very heavy thing including the 'double plate' that hosts it when fully open. Its a bit of a biatch to drill out those spotwelds, but surely, the cost is GBP 0.
Also, completely strip the F and R bumper so that you just have the outer skin left. Find a way to attach that. Get rid of the shock absorbers that hold it in place now but make a simple, vulnerable replacement out of glassfibre or something. Cost GBP 30? Serious kilos to be shed there, I think some 20-30 kilos at least
As said, the sound deadening can be taken out. In my E28, it was some 11 kilos IIRC.
Glassfiber bonnet and bootlid are to be had for sub 200 quid a piece, and from what I have seen the quality is good enough for a trackcar. Will look good in flat black on a Sebring! And ofcourse, you can always keep the OEM ones . Bonnet + assembly is fairly heavy, not to mention the bootlid with locks etc. Simply put a std issue caravan light on the rear bumper for license plate illumination
Get the regular E34 replacement tank, thats plastic and weighs less
( BTW Terry & jon, I'd replace the tankstraps that hold the tank if I were you, mine failed once and they looked a lot better than those
..Especially with a full tank coming down the Karoussel, they will snap eventually. Replacement is cheap and fairly easy, just the fuel filter and SLS stuff are a bit in the way)
The holy grail for real big weighsaving lies in a lightweight exhaust IMO. The std E34 item weighs a tonne! Its near impossible to lift it high enough to fit on a hoist by a single person. Ofcourse the emissions test in UK might prohibit a complete cat-less system, but I guess some 30-40 kilo;s are to be had there aswell, ofcourse at higher cost.
