Last week I fitted a HID headlamp kit to Project Calypso - a surprisingly straightforward affair - we now have proper lighting.
We have also returned the car to original spec lighting - orange lenses at the front, side and rear.
However, today was the day Project Calypso took a more significant step forward.
The fabulous Baker Boys Jnr & Snr arrived at my place this A.M. - with our newly-purchased eBay Corbeau Seats and Willians Harnesses.
First job was to tend to a recent annoyance - our inability to get the turbine covers separated from the 17" M5 rims - the hex screws (5 on each wheel), were seized.
Jon Snr applied his engineering skills and started slowly and carefully drilling the bolts out. By Lunchtime, we were over half-way there :-
Next onto the seats - we bought a pair of Corbeau Sprint XLs - a nice seat - (and wide enough to accomodate my harris) - we had to use an angle-grinder to remove the BMW seat mounting lugs - and then part-manufacture a bracket solution.
Snr took a great deal of time and effort ensuring the fitment of the passenger seat was angled coreectly, and safely-secured :-
Meanwhile Jnr set about fixing the rear location points of the Willans harnesses to the parcel shelf. We drilled-out and used the central location points formerly holding the parcel shelf trim. The metal is strong here, however, we used a number of strengthening plates both above and below the securing eye to ensure maximum strength possible :-
The Corbeau seat brackets didn't fit the E34 too well originally - however, after much deliberation and thought - we managed to use the original brackets
and fit to the majority of the original E34 mounting points - the final solution, we were very pleased with :-
We ran out of time to start fitment of the Driver's seat today. However, it will be mounted higher than the passenger seat - to ensure the optimum position for Jon Jnr and myself. This will require the manufacture of a 40mm box section - so this will be a job for another day soon.
With the driver's seat mounted temporarily, Project Calypso is starting to look and feel more like the track-focused car we envisaged.
It may not look like it - but believe it or not - I did more than just take photos today whilst the boys worked - I made the tea too.
Big thanks to Snr who really helped Project Calypso come on leaps and bounds today :-
Once the seats are in, we then have the next stages to work on:-
- Lowering springs - probably H & R
- New tyres - probably R888s
- Fitment of the already-purchased Ferodo DS3000s front and rear
- Cure of valve gasket leak at rear of engine
The car drives well - it's a project that's a bit stop-go, and Jon and myself have been working long hours lately........
Soon we'll be on the track - and our plan is to get at least 3 trips to the ring next year - hopefully the channel tunnel will be back in action by then..
