Old 27th July 2008, 19:22   #1
dj leethal
dj leethal's Avatar
Garage: 1995 Euro M5 Arctic Silver & 1991 M5 Sebring Silver
Preventive maintenance
Just purchased a 1995 M5 here in the states. It has 80k miles on it. I want to give the car a thorough service & inspection. What should this procedure include. I want to do everything possible to keep this fine automobile in tip top shape. Vehicle is totally original, no mods.
Variety is the spice of life.
dj leethal is offline
Old 28th July 2008, 02:14   #2
Sebring NL
Sebring NL's Avatar
Get the usual things.
I am not gonna post this again. The following applies to the 3.6 :
1) Valve clearances ( make sure to get the gasket + the three small gaskets)
2) Throttlebody synch
3) S50 chain tensioner
4) vacuum hose underneath plenum etc replacement , clean cannister under the plenum ( improves sound!)
5) replace all of the ignition parts ( rotor , distr cap)
6) check or replace plugs for Bosch Y6DC ( do this during valve clearance check)
7) Toss out any existing K&N oiled air filter
8) Check the small pipe for coolant return to be open and not blocked
9) Change the SLS fluid
10) Replace water pump and carefully inspect the hoses and replace when in doubt.
Differences 3.8 :
All of the above save for # 5 being different from 3.6 as the 3.8 has different ignition. Therefore:
1) Inspect and/or replace the ignition coils if needed
2) Inspect and/or replace the injectors ( they can fail and cannot be overhauled like 3.6)
3) Inspect and/or budget up for EDC replacement
Wout
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
The Following User Says Thank You to Sebring NL For This Useful Post:
dj leethal (28th July 2008)
Old 28th July 2008, 05:18   #3
M5sedan
M5sedan's Avatar
Garage: 1993 E34 M5 3.6 - Mauritius Blue/Dove Grey; 2002 E39 M5 Carbon Black/Caramel
@ Wout - please excuse my ignorance.......why can't the 3.8 injectors be overhauled like the 3.6's?? Is it a matter of Bosch vs. Lucas??
so many mods......so little time.......
'93 E34 M5 - Mauritius Blue/Dove Grey - 3.8 cam gears, Conforti chip, SLS-delete Ground Control/Koni suspension, Alpina Softline 18's, Rogue Engineering short shifter, Eisenmann Race exhaust
'93 E34 M5 - Avus Blue/Dove Grey - 18" M-Parallels
SOLD & Sorely missed: '02 E39 M5 - Carbon Black/Caramel - Rogue short shifter, Rogue Power Pullies, opened brake ducts, ellipsoid fogs, slide/tilt armrest
M5sedan is offline
Old 28th July 2008, 05:46   #4
dj leethal
dj leethal's Avatar
I pretty much have most of that on my list & then some. Except # 4 & # 8 . (3.8) #1 , #2 . Just want to see if I missed anything. I want to do the most thorough service I can . This M is in great shape & I want keep it like that. Thanks for the input.
Old 28th July 2008, 19:15   #5
Dan Kelly
Garage: E34 M5 Sterling Silver
To add to Wout's list
  1. Check upper and lower control arms
  2. all shocks for leaks/function
  3. engine belts
  4. Rear sub frame bushes
  5. Replace all fluids (diff,gearbox,brake,clutch and coolant)
  6. KDS alignment
Dan Kelly is offline
Old 29th July 2008, 12:23   #6
Sebring NL
Sebring NL's Avatar
exactly
Old 29th July 2008, 12:41   #7
E34_nut
E34_nut's Avatar
Garage: E34 540i LE 6sp. - Calypso Red / Black Leather
Should this go in the FAQ
To the moderators.
Given Wout's initial response, should this thread get put in the FAQ ?
Reg.
from THE Antipodes , the real Land of Aus.
"You're gunna die of something, it might as well be fun !"
'88 Ducati 851 Superbike Strada - the original tricolour
'83 Ducati Mike Hailwood Replica - "900" kick start
Imagine a luxo like an E38 "L" with the current 4.0L Diesel !
E34_nut is offline
Old 29th July 2008, 17:14   #8
corneredge
Garage: 1994 M5 3.8L Avus Blue
And when that list is done, take it to Don Fields so he can give it a once over and you'll be in great shape.
-Russ
corneredge is offline
Old 29th July 2008, 19:55   #9
dj leethal
dj leethal's Avatar
I am in the process of bringing the M to Don today. I am about to call him & let him know I am coming. He will be the one executing the list of things to do.
Old 30th July 2008, 01:34   #10
dj leethal
dj leethal's Avatar
I read some where that the rod bearings should be inspected & replaced if necessary . This M has 80k miles. Does anyone think I should add that to my list. I just want to cover everything I can. I really love this car & want to do the best I can to keep it in tip top running condition as well as looking good.
Advise needed...my full maintenance is running out... Lange E39 M5 and E52 Z8 Discussion 3 8th May 2007 07:01
Preventive Maintenance? CWY_M5 E39 M5 and E52 Z8 Discussion 11 7th November 2006 08:30
Good News! You can buy ext. maintenance to 6/100! Chris Foote E39 M5 and E52 Z8 Discussion 36 21st February 2004 01:09
BMW Maintenance Plan Upgrade Program & Pricing Bokke E39 M5 and E52 Z8 Discussion 1 20th February 2004 07:21
What's included in full maintenance? jdh E39 M5 and E52 Z8 Discussion 2 30th April 2003 04:38
Page generated in 0.23521 seconds with 12 queries
