Door mouldings / bump strips - BMW M5 Forum and M6 Forums
Old 14th July 2008, 13:01   #1
Mmm-Five
Registered User
My door bump strips on the near side (UK passenger side) are starting to come away from the clips, and no amount of pressure will keep them in place. So I've decided to replace the lot - 4 on each side as far as I can see.
When I go to ETK it shows me 6 strips for each side...nos 1, 2, 3, 4, 7, 8)
Nos 1-4 look like the ones on the car, but where are nos 7 & 8 on the car? And, do I need them?
TIA
Mmm-Five is offline   Reply With Quote
Old 14th July 2008, 13:45   #2
Baddie
Garage: M5 Daytona Violet 3.8
Are they the bits that finish off the sill?
If you focus on quality, you don't need to worry about quantity.
Baddie is offline   Reply With Quote
Old 14th July 2008, 14:52   #3
Mmm-Five
Registered User
If you mean the contrasting sill, then no. If you mean the bottom-of-the-door trim, then yes.
They seem to be the bits that would go on either end of nos. 12 & 13 in this picture...
I suppose they were included in the first diagram as they clip on to the front/rear wings in the same manner as the door strips do.
I definitely don't need those bits then.
Right, who's betting these are special order from the North Pole then?
Old 14th July 2008, 16:15   #4
IvanDias
IvanDias's Avatar
I think the pictures are not clear.
Parts 12 and 13 are the bottom trims that clip to the underside of the door.
I think original poster is talking about the strips that adorn the middle of the door, halfway up.
I cannot see where parts 7 & 8 would go either.
Here is part 1 and most of part 2;
And here shows parts 1, 2, 3 and 4
Note on this picture, parts 12 and 13 the bottom trims on the door are removed, as is part 2 on Mmmfive's post picture the main bodykit sill.
I don't see where the two parts 7 and 8 go, unless they are behind the wing and rear arch and bolt/screw onto the chassis providing a base for parts 1 and 4 to clip on to?
IvanDias is offline   Reply With Quote
Old 14th July 2008, 17:00   #5
Mmm-Five
Registered User
Ivan, it looks like parts 7 & 8 are the ends of 12 & 13. I think they've just been included on the wrong diagram.
The only thing they can be are the 'covers' at the very bottom of the wings before the contrasting sill - if you look at the bits of the sill/skirt that you've taken off, then 12 & 13 are above that. I think 7 & 8 are in line with 12 & 13, but just as opposite ends of the car - the rear bit only being 2-3 inches.
Old 15th July 2008, 17:01   #6
dronfieldm
Garage: Range Rover now, had 1995 BMW M5 3.8 6 Speed - Avus Blue
Tony,
I know you have probably made up your mind, but if you gently squeese the "trough" on the back of the black door strips with a pair of pliers, where it mates to the clips on the door, they clip on again fine.
If you look on the back of the strips, you should see what I mean. The clip on the door sits inbetween 2 plastic strips (creating a sort of groove), so if you squeeze them together it makes a better tighter fit (!!) and fastens back OK. Think they open up over time.......
Just a thought.
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline   Reply With Quote
Old 15th July 2008, 17:14   #7
Mmm-Five
Registered User
Thanks Mark, but I've had a look at the clips and grommets and they're a bit knackered anyway, plus some of the trim itself is cracked.
I've just ordered a complete set for one side for about £70 and I'll then see if it's worth doing the driver's side too.
All the parts are in the UK and will be at the stealer's tomorrow.
Speed bump damage Mmm-Five E34 M5 Discussion 14 2nd February 2009 11:15
Do I need to cut my bump stops? DrLev99 E60 M5 and E61 M5 Touring Discussion 29 18th May 2008 07:31
Cleaning plastic rubbing strips? rassi E39 M5 and E52 Z8 Discussion 21 18th November 2007 21:06
license plate cover between bumper impact strips B3ND3R E34 M5 Discussion 2 6th May 2004 00:23
Body colored strips for the M5 Rezf E39 M5 and E52 Z8 Discussion 17 17th July 2001 00:00
