Originally Posted by raymondw
Yes, it was the old rad (11 years old when I sold the S2 in 2005). The rad in my E34S is 18years old and doesn't have such damage though, but that one has always been run on 100% glycol (nitrate free) that has been replaced everey 4yrs since I have owned it. I suspect it has to do with adding a mixture of water and antifreeze. The minerals in the (not demineralized) water will react with the pipework reducing the flow capacity and increasing the pressure in the rad.
I thought it was NOT recommended to run on pure glycol(antifreeze) the recommended mixture should be 50/50.
I run my M5 with this, just changed every 3-4 years. Original rad. changed as part of preventive maintenance summer 2007, It still looked like new externally.
I would tip road salt+internal corrosion due to neglected cooland changes previously in the cars life and time of course.
Using tap water in the coolant could be an issue, It was used in my car without any detrimental effect but after the new rad was put in, distilled water was used.
Sakke
