Old 12th July 2008, 00:05   #1
///Manuel
Garage: various cars
Mystery box next to ECU
I found this box next to my ECU, it looks like I can adjust timing with it.
Turning the little knob doesn't seem to have any effect on how the car runs.
Anyone else has that?
EDIT: 12D3-100SSTB 30AMP is on the back of that box.
///Manuel is offline
Old 12th July 2008, 00:14   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
my guess would be that it has something to do with the US federalization process. Maybe related to cold start.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 12th July 2008, 00:18   #3
m5 deamon
m5 deamon's Avatar
Garage: 2001 e39 m5 carbon black on black sport interior
Send a message via AIM to m5 deamon
looks like a piggy back of some sort is there a part number on it from bmw ?
2001 m5 Carbon Black, Black sport interior, m audio
AA cai with bmc air filters
AA software going to change to either ess or pc
UUC Light Weight FlyWheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmisson mounts
Steelbraded clutchline
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braded brake lines
Dinan rear sway bar
Dinan stress bars front and rear
Tc swaybar brackets
PS2 tires
Axiss ult pads front and rear
Dinan JRZ suspention kit
Euro head lights
Predator ice v2.1 angel eyes
Bimmian black kidney grills
DDM xenon fog lamps
Solaris amber bulbs
led lic plate lights
v1 hardwire
m45 blinders updated version
To Come... dinan headers, stoptec bbk
m5 deamon is offline
Old 12th July 2008, 00:55   #4
///Manuel
Both boxes are black with nothing written on them except for what there is on the pic.
EDIT: Sorry didn't look with my eyes open, 12D3-100SSTB 30AMP is what's on the box.
Old 12th July 2008, 16:21   #5
E34_nut
E34_nut's Avatar
Garage: E34 540i LE 6sp. - Calypso Red / Black Leather
Context of the word "Timing" may NOT be spark related.
Hi Manuel. The reference to timing maybe something completely different. For instance, if the car used to have a turbo-charger, the "timing" adjustment maybe how long the engine ran after the ignition had been turned off.
Any idea what is/was connected to Pins 2 & 3. If you can figure that out, it could make "filling in the blanks", a little easier.
Reg.
from THE Antipodes , the real Land of Aus.
"You're gunna die of something, it might as well be fun !"
'88 Ducati 851 Superbike Strada - the original tricolour
'83 Ducati Mike Hailwood Replica - "900" kick start
Imagine a luxo like an E38 "L" with the current 4.0L Diesel !
E34_nut is offline
Old 12th July 2008, 22:42   #6
jrobbo
jrobbo's Avatar
Garage: BMW E34 M5 Macau Blue
Just need to know where pin 2 goes, as pin 3 most likely goes directly to ground going by the diagram.
I doubt very much that it could be adjusting them timing, as it doesn't appear to have any timing input, so there is nothing to adjust
It looks to be something like a turbo timer as Reg suggested, or could be doing something like keeping the headlights on, or the aux fan on for a little while after the ignition is switched off
My E34 M5: http://www.jrobbo.com/M5
License Plate: "EUROM5", VIN: "GA25294". Come and get me!
jrobbo is offline
Old 12th July 2008, 22:59   #7
mottati
mottati's Avatar
it could also be to time the smog pump on a cold start, since the US smog pump has a slightly different run cycle than a euro spec car. (from what i've heard. Our smog pump starts immediately with a cold start, i've heard that a euro 3.8 starts 30sec or so after cold start).
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 12th July 2008, 23:41   #8
nebpor
Garage: Avus Blue E34 3.8 M5
That is correct
nebpor is offline
E39 steering box into 540i - servotronic questions Retset E39 M5 and E52 Z8 Discussion 25 17th September 2009 05:14
M6 Kelleners / Schrick Cams, Active Autowerke CAM ECU, Supersprint X-Pipe & Mufflers KeithTa E60 M5 and E61 M5 Touring Discussion 73 19th January 2009 06:42
E34 M5 Six speed box Wane Ramsay For Sale or Wanted 1 29th January 2008 17:06
Active Autowerke M5 ECU Upgrade TOPSUPRA E60 M5 and E61 M5 Touring Discussion 312 24th May 2006 16:17
SALE: M5 Steering box (non servotronic) euaniebabs For Sale or Wanted 2 6th April 2006 20:30
Page generated in 0.13747 seconds with 11 queries
