Old 9th July 2008, 01:07   #1
davidoli
How important is the mesh protection grid on MAF ?
Hi Guys , on returning from a disappointing Rolling Road session in Sebring Sienna today , I removed my MAF , which was identified as potentially being the problem , to discover that it was missing the mesh protection grid on the rear end nearest to the plenum .
How important is this grid and what is it's exact function ?
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 9th July 2008, 10:36   #2
BT-Jim
Garage: Bi-Turbo in Blue
MAF downstream mesh.
I wondered the same on my 500E. On the Mercedes the upstream one will help with ensuring a uniform flow over the sensing elements and keep debris and fingers out. The downstream one I guess it's just fingers...
Jim.
BT-Jim is offline
Old 9th July 2008, 11:14   #3
Rapamaha
Garage: -92 M5 3.8 daytonaviolet
No idea how important the rear grid is, but I would recall that the mesh size is different than in front grid - there must be a particular reason for that in an overengineered car like SW///?
Rapamaha is offline
Old 9th July 2008, 12:32   #4
Jon Baker
Jon Baker's Avatar
Garage: E34 M5 3.8 - Daytona Violet
D,
Not sure of its function but can tell you that FUG is running without hers, and has been for years, and nothing appears to have gone wrong.
JB
Jon Baker is offline
Old 9th July 2008, 13:32   #5
Jon Baker
Jon Baker's Avatar
D, if you don't mind me asking what did Sienna record..? What engine work has she had done on her?
JB
Old 9th July 2008, 15:29   #6
///Manuel
Garage: various cars
It's most likely to protect the engine in the event a part from the MAF itself breaks and gets loose.
///Manuel is offline
The Following User Says Thank You to ///Manuel For This Useful Post:
IvanDias (9th July 2008)
Old 9th July 2008, 19:38   #7
farrell
farrell's Avatar
Sales Feedback: (4)
The maf screen on both the 3.6 & 3.8 upstream & down stream of the hot wire element are similar guage wire
but are also different diameter so screens are handed so to speak.
They function mainly to prevent damage from fingers during filter service change primarily.
The MAF element is secured in place by emission tamper proof screws with no moving parts & all
sensor wires soldered in place.
However, the downstream mesh element often breaks up over years of use.
This is not air pressure related imho, as clumsy fat fingers seem to be the cuprit.
The front screen to the air filter housing is never failed in my experience supporting the above.
Once the downstream meash screen is damaged, the wire mesh does start
to get loosened under air pressure.
There was some past discussions many many yrs ago about an engine failing
as a result of the wire mesh being consumed by the engine.
It's possible I guess with WOT & resonance flap open but never had first hand
experience of this.
I would suggest that many downstream mesh screens that are damaged are probably removed
before this has a chance to occur.
If the screen is removed & not replaced, then it's no issue.
Just be careful not to touch the fine sensor wires soldered to the MAF charge tube.
Break one & the MAF is toast & car will not run properly or at all.
Farrell
www.darjac-racing.co.uk
farrell is offline
The Following 3 Users Say Thank You to farrell For This Useful Post:
corneredge (10th July 2008), erikm54life (10th July 2008), raymondw (10th July 2008)
Old 10th July 2008, 00:35   #8
davidoli
JB
Hi JB , as suspected and often stated by myself .....Sebring Sienna was well down on power , recording a best run of 276 bhp ....33 bhp down on my other 3.6 .....yet , SS obviously still runs reasonably well .....
Even with the fuelling variations , the best run was 276 hp .
She has only ever been set up to standard specifications , is not chipped , runs a powerflow exhaust system , has recently had valve clearances adjusted and a full inspection service .
I have just fitted a new MAF and will run some injector cleaner through .
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 10th July 2008, 13:26   #9
Jon Baker
Jon Baker's Avatar
Just goes to show how little the figures actually mean.
Bearing in mind my recent dyno figure of 341, there is no way that my car had a 65bhp advantage on SS during our last trip to the Ring!! The cars were so evenly matched on the road!!
JB
Old 10th July 2008, 13:42   #10
hertfordshire1
hertfordshire1's Avatar
Garage: BMW M5 e34
JB
Jon, stop banging on about your 341!!!!
Steve
"If it breaks again.................. I give up."
hertfordshire1 is offline
How to test the MAFs yourself and How MAFs work DavidS E39 M5 and E52 Z8 Discussion 378 2nd September 2009 03:42
maf, unpluged,pluged,runs almost the same,, bryon E34 M5 Discussion 12 4th October 2008 03:08
SESLht caused by MAF...is it just the sensors in it or do you replace the entire MAF? 911/M5 E39 M5 and E52 Z8 Discussion 16 6th March 2008 18:55
VW MAF install thread Machtig E39 M5 and E52 Z8 Discussion 15 25th December 2006 00:45
Mesh Grill in MAF graham4242 E34 M5 Discussion 4 18th October 2006 15:36
Page generated in 0.22103 seconds with 11 queries
