Old 4th July 2008, 03:34   #1
BMW Performance
BMW Performance's Avatar
Garage: e24 m6, e24 turbo
1991 m5 MAF
I have a 91 m5 that was running fine. I did some work to it (plugs, air filter, antifreeze, valve cover gaskets, shifter bushings, transmission mounts, changed the transmission fluid, changed the differential fluid, and a couple other things) and now it barely runs. I now have the check engine light for code 1215 which is Air Mass/Volume Sensor. I have checked to make sure it is plugged in and it is. The boot looks fine with no cracks or anything. The wires going to the maf look good. Anybody have any other ideas as to what I need to do? I have unplugged the connector and checked pin 2 for 12V and pin 4 for ground. I have 0 ohms on pin 3 to pin 5 (i think it needs 5 ohms resistance). I also have 5 ohms 1-2,1-3,1-4,1-5,1-6. Any help would be great.
BMW Performance is offline
Old 4th July 2008, 20:33   #2
AfricaOffroad
AfricaOffroad's Avatar
Garage: 1991 E34 M5
I'd guess you have damaged a plug lead, now have a bad misfire, this is throwing extraneous codes?
Problem has to relate to something you just worked on
1991 E34 //M5
2003 E55 AMG
2009 KTM 950 Super Enduro
2009 KTM 300 XCW
AfricaOffroad is offline
maf, unpluged,pluged,runs almost the same,, bryon E34 M5 Discussion 12 4th October 2008 03:08
SESLht caused by MAF...is it just the sensors in it or do you replace the entire MAF? 911/M5 E39 M5 and E52 Z8 Discussion 16 6th March 2008 18:55
Secondary Air fault (and a MAF for sale!) FSAEracer03 E39 M5 and E52 Z8 Discussion 5 16th August 2007 01:01
Dinan MAF Housings VetteRacer E39 M5 and E52 Z8 Discussion 26 25th April 2007 00:12
VW MAF install thread Machtig E39 M5 and E52 Z8 Discussion 15 25th December 2006 00:45
Page generated in 0.08379 seconds with 11 queries
