Old 3rd July 2008, 00:39   #1
raymondw
raymondw's Avatar
S38B36: Warning for ignition wiring-loom.
Gentlemen,
My recent experiences with my E28S M5 do affect the E34S M5 HD91, HD92. HD93 and HD98 models as well.
As some of you already know, I killed the engine of my E28S M5 in Germany now about a month ago. I just received the proof that resulted in this engine failure, a broken connector of the HV-wiring loom between the ignition coil and the distributer cap. For a more detailed description, I refer to my writeup in the E28 M5 section with pictures shown on page 9 of my write up.
I did check the wiring and its connectors not that long ago and they measured OK. But this time, the wire disconnected from the connector whilst driving on the autobahn. This caused a spark bridge in the lead with disastrous concequences. This is a risk that can affect the S38B36 engine as well. Even though a new HV-wiring loom is not cheap, this part should be part of your preventive maintenance programm.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
The Following User Says Thank You to raymondw For This Useful Post:
davidoli (3rd July 2008)
Old 3rd July 2008, 00:55   #2
Sebring NL
Sebring NL's Avatar
thanks Ray
just replaced it on an M30..
Was planning on doing so on my S38, but as you know..plan # 450, allocation september 2034
Sebring NL is offline
Old 3rd July 2008, 00:55   #3
inertia8
Garage: E34 M5 Calypsorot/Champagne
Much appreciated.
Given my current spark issues I have driven the car once since I heard of this failure on your E28.
I've opted to replace leads, dizzy cap, rotor, coil and the bottom plastic cover.
Cost was only $564 delivered, so it's not a bank breaker... the leads were $320usd and are BERU brand.
inertia8 is offline
Headlight Wiring Loom D_C_R E34 M5 Discussion 7 28th March 2009 01:58
E28S M5 #231, wrenching time => Engine rebuild (page 5). raymondw E28 M5 Discussion 89 31st May 2008 21:44
For Sale: E34 M5 ECU and wiring loom etc. enjoymentman For Sale or Wanted 2 6th December 2005 14:32
Warning about "low engine oil" warning! Nisse E60 M5 and E61 M5 Touring Discussion 15 6th October 2005 09:20
Page generated in 0.11593 seconds with 11 queries
