Old 2nd July 2008, 18:23   #1
Lantz
Lantz's Avatar
Garage: BMW M5 E34 Granitsilber Metallic 3.8
Oil Pan, Part?
My mother recently took the M5 to the airport to drop off my father, on the way back 2 of the 4 bolts holding the oil pan fell off and it dragged for quite a while and is now damaged( I am referring the the plastic "pan" under the sump ). Does anyone have the part number for it?
I looked on Real OEM but no luck.
Also will driving without it for a while be an issue for cooling or otherwise?
Thanks for the help!
Lantz
Lantz is offline
Old 2nd July 2008, 18:47   #2
erikm54life
erikm54life's Avatar
Garage: '93 Granite Silver E34 M5 Touring
Hi !
Anything you don't find on Real OEM check it out on this site:
http://bmwfans.info/original/E34/tou...1/ill-51_2069/
The part you refer to is either No. 22 or 26.
I don't think major cooling issues will arise in the short term due to the lack of these parts....though they perform a useful function.
But, as with all M5 related issues.....err on the side of caution !!
Hope this helps.
Cheers
Erik
erikm54life is offline
Old 3rd July 2008, 10:32   #3
Lantz
Lantz's Avatar
Great site, thanks Erik!
Lantz is offline
Old 3rd July 2008, 17:27   #4
E34_nut
E34_nut's Avatar
Garage: E34 540i LE 6sp. - Calypso Red / Black Leather
Finding it in the ETK
I had the same problem when I broke the same part on my 540i.
Here's how to find it in the ETK
51 (Vehicle Trim)
70 (Insulation)
51_2867 (Heat Insulation/Engine Compartment/Screening)
51 71 2 232 121 ???
I used 08/90 M5 LHD as an example
It's 51 71 8 147 355 in my car, so make sure you key in your VIN to get the build dates right.
Just don't break the Air Guide that covers the gearbox, it's no longer available for my car, so I have to try to rebuild it ! YUK !
Reg.
from THE Antipodes , the real Land of Aus.
"You're gunna die of something, it might as well be fun !"
'88 Ducati 851 Superbike Strada - the original tricolour
'83 Ducati Mike Hailwood Replica - "900" kick start
Imagine a luxo like an E38 "L" with the current 4.0L Diesel !
E34_nut is offline
The Following User Says Thank You to E34_nut For This Useful Post:
Lantz (3rd July 2008)
First DIY Oil Change Experience Mike S. E39 M5 and E52 Z8 Discussion 41 28th April 2008 17:47
Dipstick question unfoundhorsepower E60 M5 and E61 M5 Touring Discussion 7 11th February 2006 18:37
How Much $$ Do You Pay for an Oil Change?? cohenfive E39 M5 and E52 Z8 Discussion 31 4th September 2004 03:28
Anyone had oil pan replaced? RKS E39 M5 and E52 Z8 Discussion 4 10th May 2004 08:27
Persistent Oil Leak Fixed w/New Oil Pan JonB E39 M5 and E52 Z8 Discussion 2 14th June 2002 01:04
Page generated in 0.12633 seconds with 11 queries
