Old 2nd July 2008, 12:19   #1
The Other
Garage: ///M5 3.8i Daytonaviolett
MAF test L/h
E39 guys have been testing the condition of their maf's with this hidden OBC test "liters / hour". I was just wondering what kind of readings our M5's should display?
I tested with 2nd gear and just before rev cutter the result was 78,4 liters/h.
It would be nice to get more results to compare..
For summer: M5 -93 Daytonaviolett
For winter: 520i -89 Brozitbeige
For sale: 518i -85 Karminrot
The Other is offline
Old 2nd July 2008, 12:32   #2
erikm54life
erikm54life's Avatar
Garage: '93 Granite Silver E34 M5 Touring
Hi,
My car idles at 2.4-3.0l/h without the a.c. on. With the a.c it does about 2.7-3.2l/h.
I don't know if this is an accurate test for determining the efficiency of the MAF though.
A lot of other issues may throw your readings beyond acceptable values...e.g. O2 sensor.
Maybe we can do a standard speed i.e. 120km/h in 5th coupled with a temp. reading ( air temp. ) at the time and see what everyone gets....though my statement above also applies to this.
At least we'll all have a standardised method of value reporting.
I'll do mine and post the figures up ASAP.
Cheers
Erik
erikm54life is offline
Old 2nd July 2008, 15:05   #3
The Other
Originally Posted by erikm54life View Post
Hi,
Cheers
Erik
I got the test procedure from e39 thread, it is supposed to give best results ie. maximum consumption. Temp was 13 celsius when I tested.
Old 3rd July 2008, 01:38   #4
Rapamaha
Garage: -92 M5 3.8 daytonaviolet
Couple of weeks ago I was able to break barely 100l/h barrier, friend of mine reached 109l/h. For the comparison E39 530iT showed 66.8kg/h (carsoft livedata), which is equivalent for appr. 90 litres per hour.
Rapamaha is offline
Old 3rd July 2008, 10:55   #5
The Other
It seems that my maf isn't up to specs...
Old 8th July 2008, 03:34   #6
CWY_M5
CWY_M5's Avatar
Garage: '00 M5 Silver; '91 M5 white; '01 525iT white; '94 525ia Black
Mine idles at 3.4 l/h, which is wierd I think. O2 sensor is gone, so after I replace it, I'll report back on the max consumption. on my E39 M5, I can never reach the peak that everyone claims anyway....
CWY_M5
E39 M5
'00 Titan Silver
99k miles
Koni FSD with Stock Springs and Vines arms
Intravee iPOD adapter
Clear Headlight w/ angel eye (CCFL)
Rear CELIS LED lights
BlueTooth Retrofit (LOVE THIS)
V1 direct wire w/ Blinder Extreme M20
MK-IV DVD Nav upgrade w/ 16x9 wide screen monitor
M-Sports Steering Wheel upgrade
E34 M5 '91 White (Newly acquired)
110k miles
Bone Stock - make your suggestions!!!
Other BMWs:
E34 525ia '94 Black (189k mi)
- Power chipped
- Bluetooth (Motorola)
- V1 direct wiring
- HID projector headlight
- Updated suspension (DIY)
E39 525iTa '01 White (68k mi)
- V1 direct wiring
CWY_M5 is offline
Old 9th July 2008, 06:58   #7
CWY_M5
CWY_M5's Avatar
Anyone care to post their idle l/h?
CWY_M5
E39 M5
'00 Titan Silver
99k miles
110k miles
Other BMWs:
- Power chipped
- V1 direct wiring
- V1 direct wiring
CWY_M5 is offline
Old 10th July 2008, 15:09   #8
///Manuel
Garage: various cars
I'm idling at 1.6-1.7L/h and at full throttle 2nd and 3rd 48.6L/h.
It was 65F or 18C.
I think that's a problem and the reason my car feels sluggish.
EDIT: Disconnecting the MAF, it raised to 3.0 and then 2.0-2.2 after giving some throttle.
///Manuel is offline
Old 10th July 2008, 19:50   #9
AlexA
AlexA's Avatar
Garage: 92 E34 M5 Touring Diamond Black
My 3.8 idles at 2.8 to 2.9 l/h at about 50m ASL. I have a fairly new O2 sensor. Ambient temperature 22C.
AlexA is offline
Old 10th July 2008, 20:19   #10
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
guys although this is a valid tool for indication
just be aware that the OBC itself has a calibration +/- constant
so readings will fluctuate from vehicle to vehicle.
I for one wouldn't replace an expensive MAF unit on the basis of an
OBC consumption reading alone.
I hope this makes sense...dont want any cases of the tail wagging the dog!
Alan A.
///M5 the only substitute for capacity is even greater capacity...
Alan Archer is offline
The Following User Says Thank You to Alan Archer For This Useful Post:
davidoli (10th July 2008)
Mafs test info request after disapointing dyno nerio02 E39 M5 and E52 Z8 Discussion 5 7th February 2008 18:05
TECH: How to accurately compression test an S62 engine DavidS E39 M5 and E52 Z8 Discussion 18 1st March 2007 02:34
MAF test...weird results? derck_mullin E39 M5 and E52 Z8 Discussion 21 5th February 2007 00:32
Another MAF report R748 E39 M5 and E52 Z8 Discussion 3 7th May 2006 19:47
MAF test - Another way M5DAL E39 M5 and E52 Z8 Discussion 9 31st March 2006 00:51
Page generated in 0.14568 seconds with 11 queries
