Old 10th July 2008, 21:07   #11
///Manuel
Garage: various cars
Alan, excellent point, according to my OBC I am getting 30mpg after some serious spirited driving (trying to get a feel for how the engine is running), it should be more like 8. It's not necessarily the MAF's fault.
///Manuel is online now
Old 10th July 2008, 23:33   #12
nebpor
Garage: Avus Blue E34 3.8 M5
Manuel, have you tried removing the ECU for 10 minutes to reset it? Either that or there is a procedure in the manual to reset the MPG figure!
nebpor is offline
Old 11th July 2008, 18:59   #13
///Manuel
I reset my OBD and that's what it gave me. I checked my fuel pressure last night and it stays right around 50, a little more when throttle is applied (52-53psi) and a little less when released (48ish).
Old 11th July 2008, 19:53   #14
overflowpy
Garage: 1991 M5 34 S38B36
My car mark 3.4 to 3.5 l/h My car no have a O2 Sensor and I don't know is originally came with O2 sensor
overflowpy is offline
Old 11th July 2008, 22:18   #15
davidoli
Another sensor that can affect the fuelling is the air temp sensor that is situated in the lower half of the airbox , below the MAF .
A friend's car recently had a faulty air temp sensor whereby it was recording the air temp as minus 3 degrees all of the time and therefore over fuelled , believing the air to be denser than it actually was .
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
The Following User Says Thank You to davidoli For This Useful Post:
nebpor (11th July 2008)
Old 19th July 2008, 17:42   #16
rapiddecline
Garage: E34 M5 brilliant red
I do not rely on the sensors or the obc the only way I check this is to fill the tank to the neck -- drive to wherever--- refill to neck and calculate fuel used by distance travelled . This then I find more accurate than the obc my last trip involved 1600 miles including a few 150 mph blasts 8 ring laps and a few refills. I added they amount of fuel used and calculated with the milage to 26.6 miles to the gallon. I dont think I can complain at that.
andy
rapiddecline is offline
Mafs test info request after disapointing dyno nerio02 E39 M5 and E52 Z8 Discussion 5 7th February 2008 18:05
TECH: How to accurately compression test an S62 engine DavidS E39 M5 and E52 Z8 Discussion 18 1st March 2007 02:34
MAF test...weird results? derck_mullin E39 M5 and E52 Z8 Discussion 21 5th February 2007 00:32
Another MAF report R748 E39 M5 and E52 Z8 Discussion 3 7th May 2006 19:47
MAF test - Another way M5DAL E39 M5 and E52 Z8 Discussion 9 31st March 2006 00:51
Page generated in 0.16639 seconds with 11 queries
