Old 27th June 2008, 00:08   #1
wtr
Garage: diamond black E34 M5 3.8
Is my M5 running too cold?
So the problem is that on the cruising speed (>60km/h) my coolant temp gauge points like two or three minutes to 12 o'clock, even when the outside temperature being like +20 C it takes though just few stops and accelerations and the gauge will point just 12 o'clock but never when cruising for longer trips... I wouldn't be bothered at all, unless i hadn't the feeling, that fuel-economy would be better and car would run smoother (perhaps quicker too?) with coolant temp being +90C (gauge pointing at 12o'clock). Ah yes, the fan coupling has been replaced about 50000kms and the thermostat about 1500kms ago, both with original parts naturally. Could there something that would solve this problem or is this just normal for an M5 (3.8 -92)?
Thanks in advance and sorry for my confusing english
wtr is offline
Old 27th June 2008, 00:49   #2
IvanDias
IvanDias's Avatar
Just to clarify;
Driving normally and once warmed up, coolant needle tip is about 2mm to the left of the halfway white line.
Driving hard, coolant needle covers line and points straight up.
Driving very hard and in hot weather, coolant needle edges just fractionally over halfway mark.
Congratulations, your car is working perfectly!!
Regards
Ivan.
P.S. Start engine when cold, open coolant expansion tank lid and look inside and towards windscreen for a tiny black pipe that should be pouring a small amount of coolant in and around the tank. If you cannot see this tiny waterfall, the pipe may be blocked. I will post a pic tomorrow. A very useful preventative maintenance check, but I think your car will be fine.
IvanDias is offline
Old 27th June 2008, 00:52   #3
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
Just before half way or at half way is normal
BMW's have nicely engineered temperature gauges !!!!
They sit very close to central unless engine temperature increases massively!
My gauge has nevergone beyond half way in 10 years.
Forget economy/efficiency....you do NOT want a hot running S38
as it only has basic detonation protection via fuelling.
Alan.
ps....your English is fine
///M5 the only substitute for capacity is even greater capacity...
Alan Archer is offline
Old 27th June 2008, 01:20   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
the thermostat in these cars is a 79C unit, and you're gauge function sounds normal to me.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 27th June 2008, 02:56   #5
bmwm5lover
bmwm5lover's Avatar
Garage: 1991 M5-Black/Black- 1990 Range Rover Classic SandGlow/Tan
Send a message via Yahoo to bmwm5lover
Mine runs the same. Glad to know it is normal.
1991 M5 US Spec with some goodies...
bmwm5lover is offline
Old 27th June 2008, 10:52   #6
erikm54life
erikm54life's Avatar
Garage: '93 Granite Silver E34 M5 Touring
Originally Posted by IvanDias View Post
Just to clarify;
Even with our very hot and humid climate this is exactly how my car runs.
....so you have nothing to worry about....
Cheers
erikm54life is offline
Old 27th June 2008, 15:57   #7
wtr
nice to hear that...thanks for answers and I suppose my car is also behaving normally, when it comes to oil temperature? It climbs to 90C normally, and during harder driving little warmer.
wtr is offline
Old 27th June 2008, 16:28   #8
nebpor
Garage: Avus Blue E34 3.8 M5
Yes, 90C is also fine for oil - your cooling is working well
nebpor is offline
Old 27th June 2008, 16:42   #9
Josco010
Garage: e30 m3 evo1 Lach silver
Hi EricM5, i need my curriousity satisfied are you running an M5 in Nigeria must be difficult doing this!! Please let me know these is true... i have an e30 evolution i have kept in storage and just got an e34 m5 so considering if i should send car to Nigeria or to spain, By now i guess you would assume i am Nigerian and you would be right..
Josco010 is offline
Old 27th June 2008, 16:56   #10
Lantz
Lantz's Avatar
Garage: BMW M5 E34 Granitsilber Metallic 3.8
My water temp is just a fraction to the left of the centre mark as it should be.
My oil temp, however, is always at 100 (running 10-60) is this normal?
If not, what should I check?
Note: I used to run 10-40 and it still ran at 100 C.
Lantz is offline
Anybody running 295's on the rear? MAC M5 E39 M5 and E52 Z8 Discussion 6 16th April 2007 20:49
Running in-observations Geach E34 M5 Discussion 24 20th February 2007 22:41
Cleaned my MAF sensors, solved my problems of hesitation, rough running on cold start 12sec4dr E39 M5 and E52 Z8 Discussion 12 11th January 2007 21:20
Cold running problems jmlutz01 E39 M5 and E52 Z8 Discussion 8 19th August 2004 20:01
'02s and '03s running rough when cold? schnelleM5 E39 M5 and E52 Z8 Discussion 18 22nd April 2003 22:34
Page generated in 0.17758 seconds with 11 queries
