Old 24th June 2008, 02:02   #1
Nilocnut
Registered User
Nilocnut's Avatar
Garage: 1991 bmw m5 3.6 gloss black
Interior door panel repair
Hi Lads,
Before it try it "my own way" (prob a ballsup!), can anyone tell me the best way to repair/restick the vinyl covering on the door cards?
The rears are worst, with the vinyl de-laminating from the shaped area under the armrests.
I know practise makes perfect, but i want it perfect first time!
Cheers
Colin.
Nilocnut is offline
Old 24th June 2008, 10:10   #2
legacy260
legacy260's Avatar
Garage: BMW E 34 LE M5 Rosso Red
Why not go and buy some new door cards or talk to a breakers to get a replacement?
"Life's journey is not to arrive at the grave safely in a well-preserved body, but rather to skid in sideways, totally worn-out,shouting, 'Holy sh*t! What a ride!'"
E34 M5 LE 20/50 Rosso Red
legacy260 is offline
Old 24th June 2008, 12:04   #3
IvanDias
IvanDias's Avatar
I wanted a new black leather drawer front for my car.
BMW told me there were three different leathers in black alone!
As most E34's are straight crushed now instead of broken for parts, matching interiors with a breaker can be more difficult than it was a few years ago.
The biggest breaker in my town has now closed their area from the public, so no more going into their place and browsing through all the BMW's picking the best bits, you have to stand at the counter and ask the staff for specific parts!
Gone are the days of finding big brake E32s for peanuts or spending an hour getting walnut trim out of smacked 540i's.
Back on topic, I thought the delamination was covered on www.bmwe34.net but the site is down at time of writing.
Regards
Ivan
IvanDias is offline
Old 28th June 2008, 23:42   #4
Nilocnut
Registered User
Nilocnut's Avatar
New door cards are £1300 plus vat a set
Even plain E34's are getting increasingly rare in the breakers now, and even if I found one the chances are the door cards would be the same or worse than the ones I've got.
Going to speak to my local trim shop next week (about leather?).
Will keep you posted.
Colin.
Nilocnut is offline
Old 29th June 2008, 09:56   #5
inertia8
Garage: E34 M5 Calypsorot/Champagne
Regards
Ivan
It's been re-cajiggered by the look of it...
http://www.bmwe34.net/Wiki/tiki-index.php
inertia8 is offline
Old 29th June 2008, 16:14   #6
Nilocnut
Registered User
Nilocnut's Avatar
Thanks,
But i could only see how to remove the door card,nothing on the repair of the de-lamination.
Colin.
Nilocnut is offline
Old 29th June 2008, 19:36   #7
AfricaOffroad
AfricaOffroad's Avatar
Garage: 1991 E34 M5
I'd like to see some pics of the problem.
That said, any decent uphosterer should be able to sort the door cards out
1991 E34 //M5
2003 E55 AMG
2009 KTM 950 Super Enduro
2009 KTM 300 XCW
AfricaOffroad is offline
Old 21st January 2009, 02:16   #8
MpowerBulla
MpowerBulla's Avatar
Garage: E34 3.8 M5 calypso Red
I have noticed today my rear door cards are starting to blow the same.
Did you get them repaired??
Can anyone recomend a good interior Retrimmer in the southeast UK??
MpowerBulla is offline
Old 21st January 2009, 10:59   #9
farrell
farrell's Avatar
Sales Feedback: (4)
The days when you can do this are rapidly disapearing.
The trim item dealer listings are here one day, then gone.
Even some PT parts are becoming single / kit items.
Try buying a complete ignition lead set for a 3.6 from stealer !
Many PT parts on back order at varying times from Germany.
(Ie not in stock in Germany)
Most door cards have delaminated to greater or lesser degree.
The plastic covered rear door cards are worst in the arm rest section.
I have repaired small sections of delaminated trim by drilling a 2.5mm hole
through the back of the door card in a
couple of areas behind the delaminated section.
Then inject some automotive trim superglue in through the holes.
Wait for a a couple of mins & then push the plastic skin back down & hold it there.
It will work.
I did mine 6 yrs ago & its still ok.
If large section have delaminated, you are into heating the plastic or leather
by applying heat to the back of the door cards
then removing the leather or plastic by peeling carefully.
You then clean the door card & key the surface with schotch brite.
Then spray apply automotive trim super glue & re-apply
the leather or plastic skin working from top of door card to bottom.
Please note, automotive trim glue has some give so you can move the plastic &
leather around on contact without immediate adhesion.
Rear parcel shelfs covered in leather = good luck.
Many are not available now, especially those with apertures for electric blind.
Thats a professional re-trim imho or it will lift with direct sunlight & raised cabin temps.
The door cards are not so suceptible in this respect.
Cheers
www.darjac-racing.co.uk
farrell is offline
The Following User Says Thank You to farrell For This Useful Post:
richardbaxter (22nd January 2009)
Old 21st January 2009, 12:12   #10
Mmm-Five
Get it all retrimmed in velvet or alcantara - only about a £2k job (or £1k for a Z4 )
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
NEW : E39 HALO HEADLAMP REPAIR KIT CA Automotive M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 51 23rd September 2008 14:43
Favor: Houston residents, 5722 SW Freeway khiroshima E39 M5 and E52 Z8 Discussion 17 10th April 2008 07:31
Group Pixel Repair Deal GimmeM5 E39 M5 and E52 Z8 Discussion 73 4th November 2007 15:53
Instrument cluster repair options dcaron9999 E39 M5 and E52 Z8 Discussion 10 31st May 2007 18:58
PDR Repair details3 Off Topic Forum 0 1st January 2004 23:34
Page generated in 0.14976 seconds with 11 queries
