Just been out in the garage.
Went through a lot of stuff and finally found a code plug for an M50B25.
It would be quite difficult to take out just the white center piece, as it has arms extending down into the blue plastic of the plug.
It brakes when you pull it out.
So you would have to source out a new white center piece, and glue it in.
4 of the pins go out on top, as you can se (Under the white center)
Question is then, is it enough to have access to those 4 legs to reprogram the chip or would you need access to all 8 legs??
Any electrical engineers in here???
images here :
http://s205.photobucket.com/albums/b...o/E34%20M5/IC/
There is not a single scratch on the plug or around it.
The IC could have exchanged bulbs, so that is one reason to take it out.
To removed the VIN sticker is no problem with the plug in place, could have been done to investigate if it was possible to tamper with it
Well all in all, I got the car pretty cheap, I knew the history on it was missing, It's very strong and have no problems and i can read part numbers of it under neath.
So I'm quite confident that no matter what, I didn't throw money out the window.
But still, i find it quite interesting to find out if somebody actually knows if it was done without removing the plug for further reference.
I would imagine that one would be able to hook up wires inside the Cluster, and get access this way
Not asking for a how-to just just technical advice in the form of yes/no
I got 2 E34's, and there certainly will be more to follow, so it would be nice to know
