Old 18th June 2008, 17:07   #1
Sebring NL
Sebring NL's Avatar
Don't UNDERrev your E34 M5!
Gentlemen drivers,
Having been in the passenger seat of several E34 M5's this year and a lot more in previous years, I noticed that many drivers have the tendency to drive the car under revs.
At the Old Goat meet, I rode shotgun with many people, but I noticed quite a few shifting to third gear at very low speeds and then ramping up speed. In itself, its not a problem to keep the car at a certain speed in a high gear, but the problem starts when accelerating.
Same as riding on a geared bicycle, the force that the 'engine' has to put up when the gearing is too high is an extremely high and unnatural one. The momentum needed to spin the wheels is so high that the stress on the internals and the slowing down of the engine through the gearbox is a lot worse than , say , overrevving the car when cold. Try riding a bike up a hill in highest gear, your feet won't be able to get the paddles down although they are hardly moving.
Because of the low revs, people think it can do no harm. Well, the oil pressure on most street-engines is 1:1 related to the engine revolutions. The S38 pump is directly chain-driven by the crank, which means, low revs = low oil pressure. The car has a considerable amount of oil ( 6 litres) so its quite important that , with cold engine and thick oil, the flow is high enough. It may not be needed for cooling, but for lubrication and getting the microscopical metal and alloy parts into the oil filter ASAP.
Its OK to keep the car between 2500 and 3000 revs at any engine temp. Remember, it goes all the way up to 7250 so you'll leave 4250 revs unused. Take a look at BMW's later rev counters where cautions blocks light up at certain revs, IIRC none of them is lower as 4500 rpm in E39 M5, X5 4.8, CSL etc.
To be perfectly clear here, its ofcourse ok to do very low revs in first and second and accelerate, because the gearing is such that the momentum is enough to move the car out of those revs fast. Also, cruising at 2k revs in 3rd or 4th is no problem, just shift down if you want to accelerate.
Wout
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
The Following 7 Users Say Thank You to Sebring NL For This Useful Post:
Bayerische (19th June 2008), corneredge (19th June 2008), geecee (19th June 2008), Jon Baker (18th June 2008), M5Piojo (21st June 2008), ncaldiero (18th June 2008), raymondw (18th June 2008)
Old 18th June 2008, 17:26   #2
m5 deamon
m5 deamon's Avatar
Garage: 2001 e39 m5 carbon black on black sport interior
Send a message via AIM to m5 deamon
very valid points made thanks for the write up
2001 m5 Carbon Black, Black sport interior, m audio
AA cai with bmc air filters
AA software going to change to either ess or pc
UUC Light Weight FlyWheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmisson mounts
Steelbraded clutchline
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braded brake lines
Dinan rear sway bar
Dinan stress bars front and rear
Tc swaybar brackets
PS2 tires
Axiss ult pads front and rear
Dinan JRZ suspention kit
Euro head lights
Predator ice v2.1 angel eyes
Bimmian black kidney grills
DDM xenon fog lamps
Solaris amber bulbs
led lic plate lights
v1 hardwire
m45 blinders updated version
To Come... dinan headers, stoptec bbk
m5 deamon is offline
Old 18th June 2008, 18:04   #3
Blutarsky
Blutarsky's Avatar
Garage: Beast
great info, thx Wout
"If everything seems under control, you're just not going fast enough" - Mario Andretti
4/91 Sebring,Blk,M-cloth
Scottsdale, Arizona USA
Blutarsky is offline
Old 18th June 2008, 19:14   #4
davidoli
Wout .......you are a Legend !
Where did this inspirational piece of writing come from ?
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 18th June 2008, 19:39   #5
Lantz
Lantz's Avatar
Garage: BMW M5 E34 Granitsilber Metallic 3.8
Its true, a real fountain of wisdom and always generous to share ( rather undutch like I may add)
Lantz
Lantz is offline
Old 18th June 2008, 20:09   #6
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
Old BMW owners manuals always stated a minimum engine speed
of 1500rpm in each gear.
People need to take time & effort to understand the gearing / torque characteristics of their cars....
I must have won 50% of all confrontations between my M5 and other cars
by using the right gear & revs at the right time.
The result of course is two tail pipes, a tricolour badge and a roundle.
Good post Wout
///M5 the only substitute for capacity is even greater capacity...
Alan Archer is offline
Old 19th June 2008, 00:02   #7
davidoli
100% agree on the importance of this Alan !
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 19th June 2008, 00:30   #8
vadas1
vadas1's Avatar
Garage: 1994 m5 / diamond black
Good post Wout
I recall the handbook on my 325i recommending that the engine revs should be between 2000 and 3000 as often as possible to preserve the integrity of the engine and drivetrain. I have to admit that in town in slow traffic I don't in the least bit mind leaving it in second for prolonged periods and shifting up to third only when the traffic smooths out. Mind you, on the way in the lack of cars on the road means I get to do the same trip in fourth and fifth. Makes getting up early worth it.
ralph (vadas1)
* If it ain't broke fix it till it is *
vadas1 is offline
E34 E39 comparison unespekta E39 M5 and E52 Z8 Discussion 22 24th May 2006 00:51
E34 E39 comparison unespekta E34 M5 Discussion 5 16th May 2006 18:11
E34 vs E39 M5 Impressions WylM5 E34 M5 Discussion 6 23rd April 2006 16:44
E34 M5 owners weekend (5 till 8 September 2003) raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 5 28th September 2003 09:32
Alpina/BMWM5.com meeting at Nurburgring Oldtimer Grand Prix 2003 kees ALPINABoard.com | BMW Alpina Discussion 15 20th September 2003 02:46
Page generated in 0.13937 seconds with 11 queries
