Hi Farrell.
Thanks very much for taking the time to follow this up with me. The reason why I'm trying to avoid having to lower the car and "reraise it" is as follows. Right now the rear suspension is also out of the car. I cannot refit it, because the company (not BMAparts BTW) supplying the parts required to fix the rears, originally committed to ship them in the last week of May, then the first week of June, then finally did so in the second week of June.
I spent every second day sending emails and making phone calls requesting a tracking number but it was never given to me.
On Tuesday, the parts were returned to the supplier saying they couldn't find that address in
Austria.
Since I live in
Australia, that's no surprise really ! The parts are supposed to have been reshipped to Australia today (I hope). I'm still waiting for the tracking number.
Why do I mention the rears when this discussion is about the fronts ! When I lower the car, the front wheels will touch the ground and position themselves with a narrower track than would occur if the car was driven to a stop. This means the wheels will be abnormally loaded unless I can move the car a small amount backwards and forwards to unload the stresses normally present when a car is lowered off a jack. Without rear wheels I can't do this.
I'm trying to at least finish the fronts so that when the parts for the rears arrive I will have less to do !
Originally Posted by farrell
The axle stands are under the vehicle I guess.
Correct. The stands are supporting the vehicle body, not the axles.
If I have this right, you can't see the difference between tightening the hub nut with the wheel on the hub & loaded with the weight of the vehicle with hub nut static on the ground, compared to trying to tighten a nut on to the end of a free sprung hub
If the phrase "free sprung hub" means a strut, properly attached to the vehicle with hub fitted to the stub axle and secured with a hub nut to about 30 or 40Nm and no wheel on it then, correct.
that will move the strut against spring load vertically upward if you pull up
I agree.
or downward if you push as you apply torque with the tool.
Not sure that I agree, since the suspension is at full extension right now and can't be extended any further when the force required to torque the nut is applied downward.
As well as a very large nut with very small load bearing lands for size moving about, you will put stress on other potential parts
I think the size of load bearing faces on the nut are a problem with either process. With the wheel missing, there is no requirement to have an extension between the torque wrench and the socket, which reduces the likelihood of the socket slipping off the nut.
Stressing other parts is something I hadn't thought of.
My analysis is as follows.
I think there are 6 parts that will suffer the extra load when I torque the nut by applying a downward force on the torque wrench.
- the 3 nuts securing the strut to strut towers
- the nut securing the piston rod to the top strut mount bearing
- the bearing in the top strut mount
- the "pinch overs" that hold the bearing in the top strut mount
- the top cap of the shock absorber case
- the nut and threaded end of the piston rod securing the piston to the piston rod in the shock absorber
Assuming a wheel + inflated tyre, does weigh about 25kg, these 6 parts all have to be capable of dealing with the force associated with that weight. Funnily enough that's very close to the same force I'm going to apply to the stub axle when I put 290Nm of torque on the bearing nut using a 1.2m long torque wrench. Since all these parts cope with the force associated with that weight, they should be well and truly capable of dealing with the force required to torque up the nut.
& run the danger of not getting a fixed torque value against the hub which could then allow the hub to work against an undertorqued nut.
I agree. This is possible if you pull up on the torque wrench. Some of the force applied will compress the suspension spring. NOTE TO SELF, DONT DO THIS IF I PROCEED.
1. You could get very hurt trying to apply the torque to a sprung hub in motion.
There will be no motion if I'm pushing down on the torque wrench. The suspension is at full extension.
2. You could have a knackered wheel bearing in short order.
I have already "nipped" the hub nut up with the socket whilst ensuring the hub is properly seated on the inner race. I have fitted the disc and caliper to the "lightly" secured hub and the disc spins correctly and is aligned with the caliper. I think this check removes this as a potential problem.
3 You could have a wheel fall off the car which is very inconvenient.
Inconvenient. There's nothing quite like the understatedness of the English !
Perhaps I am missing something that pics would high light more clearly.
Having injured myself a couple of times in recent months, I would suggest the path of least resistance is also the safe path, even if it takes longer.
Once again, thanks for your reply. The content of your responses has made me further analyse the risks and that is exactly what I was hoping would occur. This has been valuable for me.
Since I won't be able to do any more on the car until the day after tomorrow, I thought it worth while investing some time with the wealth of experience that the participants on this board can focus on a problem to try to save the time. If nobody could show me a sound mechanical or safety reason why my proposal wouldn't work, I could use that time to complete a few other bibs and bobs that need doing, before the rear suspension bits arrive.
Thanks and regards,
Reg.
