blown fuse 21 - BMW M5 Forum and M6 Forums
Old 13th May 2008, 18:05   #1
CWY_M5
CWY_M5's Avatar
Garage: '00 M5 Silver; '91 M5 white; '01 525iT white; '94 525ia Black
blown fuse 21
I have a 91 E34 M5 that I'm revamping the entire suspension. Making good progress so far, but my fuse 21 (charging socket) keeps blowing out, and as a result, my interior lights go out.
Any ideas??
Anyone knows what else is fuse 21 is connected to?
CWY_M5
E39 M5
'00 Titan Silver
112k miles (since 64k)
Koni FSD with Stock Springs and Vines arms
Intravee iPOD adapter
Clear Headlight w/ angel eye (CCFL)
Rear CELIS LED lights
BlueTooth Retrofit (LOVE THIS)
V1 direct wire w/ Blinder Extreme M20
MK-IV DVD Nav upgrade w/ 16x9 wide screen monitor
M-Sports Steering Wheel upgrade
E34 M5 '91 White
115k miles (since 110k)
Bone Stock - make your suggestions!!!
Dinan stage 1 suspension with rear SLS delete
Other BMWs:
E34 525ia '94 Black (227k mi since 83k)
- Power chipped
- Bluetooth (Motorola)
- V1 direct wiring
- HID projector headlight
- Updated suspension (DIY)
E39 540iTa '00 White (74k mi)
- V1 direct wiring
E39 525iTa '01 White Sold...
CWY_M5 is offline   Reply With Quote
Old 14th May 2008, 16:18   #2
E34_nut
E34_nut's Avatar
Garage: E34 540i LE 6sp. - Calypso Red / Black Leather
According to the ETM, the following
FUSE 21 - 10A
Licence Plate / Trunk Light
Interior Lights
Glove Box / Cigar Lighter / Charging Socket
Anti-theft for Alpine car stereo
In my car the trunk light wire was severed by hinge mechanism for the lid.
The symptoms were no trunk light, but it could have just as easily been a blown fuse.
The ETM, claims the wire providing power to the trunk light Red/White (RT/WS)
Reg.
from THE Antipodes , the real Land of Aus.
"You're gunna die of something, it might as well be fun !"
'88 Ducati 851 Superbike Strada - the original tricolour
'83 Ducati Mike Hailwood Replica - "900" kick start
Imagine a luxo like an E38 "L" with the current 4.0L Diesel !
E34_nut is offline   Reply With Quote
Old 21st May 2008, 20:26   #3
CWY_M5
CWY_M5's Avatar
Thank you, but unfortunately, it keeps blowing the fuse, I suppose I need to check all that's listed above to see if anything is shorted? Any good way to check?
Old 21st May 2008, 21:49   #4
E34_nut
E34_nut's Avatar
Blowing Fuse
Does the fuse blow the second it is replaced ?
Old 22nd May 2008, 00:04   #5
CWY_M5
CWY_M5's Avatar
No, when I replace it, all the interior lights work again, but then I don't know when it blows the fuse... seems like when I drive it for a few times, it blows it.
I'll swap it again, and let the car sit, see if it still blows it. Any ideas.?
Old 22nd May 2008, 09:25   #6
E34_nut
E34_nut's Avatar
Determining the Problem.
Solving intermittent problems like this may take a while, so you're going to need to be patient as we step through this.
All wires from Fuse 21 are coloured Red (Rot) with a White (Weiss) stripe (Rt/Ws)
Here's a description of the circuit.
Fuse 21 >-rt/ws-> Join X207
X207 is in the Front Fuse Box.
Join X207 >-rt/ws-> Connector X15 Pin 22 >-rt/ws-> Charging Socket
Connector X15 is 30 pin, White and is located
"Below LH side of dash, near kick panel, left of the steering column"
Join X207 >-rt/ws-> Connector X14 Pin 16 >-rt/ws-> Join X435
Connector X14 is 30 pin, Yellow and is located
"Below LH side of dash, below driver footrest"
X435 looks like it is located beneath the rear seat in front of the rear fuse box.
Join X435 >-rt/ws-> Alpine Stereo Anti-Theft Module Pin 11
Anti-theft module is located "below LH rear seat"
Join X435 >-rt/ws-> Trunk Lid Switch
Trunk Lid switch is located "in centre of trunk lid in trunk latch assembly"
Join X435 >-rt/ws-> Connector X355 Pin 2 >-rt/ws-> Interior Rear Right Light
Connector X355 is 3 pin, White and in the RH C-Pillar
Join X435 >-rt/ws-> Connector X356 Pin 2 >-rt/ws-> Interior Rear Left Light
Connector X356 is 3 pin, White and in the LH C-Pillar
Connector X356 Pin 2 >-rt/ws-> Connector X336 Pin 2 >-rt/ws-> Front Dome Light
Connector X336 is 4 pin, White and located "In centre of windshield header" (up in the roof behind the panel that hides the sun roof motor)
I'm not sure what will happen if you disconnect the anti-theft module of the Alpine Stereo, so for the moment, I wouldn't that.
Try disconnecting each of the various interior lights, one at a time and see if the problem goes away. Sometimes when a globe fails, a broken piece of the element shorts across the 2 pieces of metal that normally support the element. Do you have an interior light that doesn't work ? This may be the problem.
Similarly, has the trunk light failed / try disconnecting the trunk light ?
I my "5", the connector for the charging socket is poorly protected (a piece of low density sponge). Has a bobby pin / paper clip or some other metallic foreign object fallen into this connector ? Try disconnecting it and see if the problem goes away. I think the Red/White cable plugs in to the back of charging connector.
Let me know how you go with all that and I'll see if I can think of a few more things to try in the mean time.
If none of that solves the problem, there's a distinct possibility that one of the wires in this circuit has compromised insultation. To blow a 10A on 12V circuit, the resistance from the appliance side (not the power side) of the fuse is going to be less than 1 ohm.
Do you have a multimeter to be able test this ?
Reg.
Old 30th June 2008, 22:13   #7
CWY_M5
CWY_M5's Avatar
So I finally have time to go into my car and test some of these, but still, no solution.
I removed all 3 bulbs (all working) in the trunk, as well as two bulbs in the rear (by the column), so only light remains are the three up front by the sunroof switch.
I replaced the fuse, and lights seem to work as usual, and remained working for a few days with car parked (I would open the door once in a while, to make sure it still works).
However, I drove the car yesterday, seem like shortly after I started the car, the fuse blown again, because my interior light won't work again... WTF?????
Do you have a diagram or something you can send via PDF? this is bugging me, I would like to remove charging socket before doing anything else.
Reg.
Old 30th June 2008, 23:21   #8
DrSakke
DrSakke's Avatar
I would once again suggest checking the wiring to the trunk lid. As removing the bulbs wont help if a live wire comes in direct contact with the ground at the hinges.
Sakke
DrSakke is offline   Reply With Quote
Old 1st July 2008, 01:27   #9
CWY_M5
CWY_M5's Avatar
I will pick up more fuses today, and see if I could duplicate this with opening and closing of the trunk, leaving car engine off... if I could, then we found the problem... question will then be, how to fix it...
first things first.
was wondering if you had a diagram that led you to all the previous very useful instructions and comments.
Chino
Sakke
Old 1st July 2008, 08:31   #10
DrSakke
DrSakke's Avatar
first things first.
Chino
Nope, just 6,5 years of ownership. Hope there is somebody else who can provide you with one.
There is the BMW TIS workshop manual freely downloadable here somewhere (1500pages) that im sure contains all the instructions and diagrams needed, I can look it up for you....
Sakke
Feedback on missing fuse? 7 speed SMG E60 M5 and E61 M5 Touring Discussion 12 7th October 2006 07:07
So where's the fuse??? London Mike E34 M5 Discussion 12 21st September 2006 09:46
blown fuse slowcar E39 M5 and E52 Z8 Discussion 0 10th October 2005 05:15
Help needed! Can't find blower motor fuse. Caribbean-M5 E39 M5 and E52 Z8 Discussion 0 28th January 2005 05:01
Heater A/C - Fan Blower - Fuse???? sctazmon E39 M5 and E52 Z8 Discussion 1 27th June 2004 21:19
