Old 7th May 2008, 05:09   #1
samiam
Garage: 1988 E32 Alpina B11 3.5 white. E34 535is white. E34 Alpina B10 black
rear door quarter glass E32/34
Anyone know how to remove the rear door quarter glass????
I've removed all the trim & door rubbers etc So now there's just the glass & it's rubber seal but it really doesn't seem to want to come out without using force & I'm worried it will break.
samiam is offline
Old 7th May 2008, 10:27   #2
Mmm-Five
It does require a LOT of effort to get the rubber trim out - if you've bought a new glass then you'll have noticed the trim is already stuck on and has a few metal clips.
The clips are a right PITA to remove, and I remember my window-fitter taking 45 minutes to remove it (using pliers/grips mainly), yet only 15 minutes to fit the new one.
I should have thought on and taken some pictures!
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is online now
Old 7th May 2008, 21:48   #3
davidoli
There is a metal strip that goes between the main window and the quarter glass .....it runs up from inside the door to the top of the door and is secured through a small opening at the top and a 10mm bolt inside .....you need to remove that first , then the quarter glass should slide out towards the main window area of the door !
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 7th May 2008, 22:54   #4
Mmm-Five
Completely forgot about that other bit to unlock - even after seeing it get done
It still looked like a bugger to remove the old window clips though
I can't even find any pictures on the 'net for it.
M3 worst nigthmare is here; BMW 1xx tii Concept Just_me E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 29 24th February 2008 20:16
dyno shops in Los Angeles or Northridge deknight E60 M5 and E61 M5 Touring Discussion 106 14th October 2007 08:09
OT New Z06 rebel1 E39 M5 and E52 Z8 Discussion 86 12th January 2005 01:43
Cleaning Rear Sunshade a_ok2me E39 M5 and E52 Z8 Discussion 6 1st January 2005 00:05
Extra tinted glass rear irfy E39 M5 and E52 Z8 Discussion 8 4th October 2000 20:57
Page generated in 0.09357 seconds with 11 queries
